[QGIS-Developer] not building against pdal 2.4.0rc1
Martin Dobias wonder.sk at gmail.com
Mon Mar 21 13:29:07 PDT 2022
Hi
Thanks for reporting the compilation issue with PDAL 2.4.0. RC1. I have
reported the issue to the PDAL developers and they have already prepared a
fix: https://github.com/PDAL/PDAL/pull/3713 - I am hoping it will land in
the final 2.4.0 release.
Regards
Martin
On Sat, Mar 19, 2022 at 5:17 PM Saulteau Don via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Trying to build qgis from the 3.24 release branch on github and testing
> against pdal 2.4.0rc1.
> It fails with the following about a missing pdal function no longer exists:
> [ 39%] Automatic MOC for target provider_pdal
>> [ 39%] Built target provider_pdal_autogen
>> [ 39%] Building CXX object
>> src/providers/pdal/CMakeFiles/provider_pdal.dir/provider_pdal_autogen/mocs_compilation.cpp.o
>> src/providers/pdal/CMakeFiles/provider_pdal.dir/qgspdalprovider.cpp.o
>> /build/qgis/src/qgis/src/providers/pdal/qgspdalprovider.cpp: In member
>> function ‘bool QgsPdalProvider::load(const QString&)’:
>> /build/qgis/src/qgis/src/providers/pdal/qgspdalprovider.cpp:235:58:
>> error: use of deleted function ‘pdal::LasHeader::LasHeader(const
>> pdal::LasHeader&)’
>>   235 |     const pdal::LasHeader las_header = las_reader.header();
>> In file included from
>> /build/qgis/src/qgis/src/providers/pdal/qgspdalprovider.cpp:32:
>> /usr/include/pdal/io/LasHeader.hpp:70:16: note:
>> ‘pdal::LasHeader::LasHeader(const pdal::LasHeader&)’ is implicitly deleted
>> because the default definition would be ill-formed:
>>    70 | class PDAL_DLL LasHeader
>> /usr/include/pdal/io/LasHeader.hpp:70:16: error: use of deleted function
>> ‘std::unique_ptr<_Tp, _Dp>::unique_ptr(const std::unique_ptr<_Tp, _Dp>&)
>> [with _Tp = pdal::LasHeader::Private; _Dp =
>> std::default_delete<pdal::LasHeader::Private>]’
>> In file included from /usr/include/c++/11.2.0/memory:76,
>>                  from /build/qgis/src/qgis/src/core/qgis.h:24,
>>                  from
>> /build/qgis/src/qgis/src/providers/pdal/qgspdalprovider.cpp:18:
>> /usr/include/c++/11.2.0/bits/unique_ptr.h:468:7: note: declared here
>>   468 |       unique_ptr(const unique_ptr&) = delete;
>> make[2]: ***
>> [src/providers/pdal/CMakeFiles/provider_pdal.dir/build.make:90:
>> src/providers/pdal/CMakeFiles/provider_pdal.dir/qgspdalprovider.cpp.o]
>> Error 1
>> make[1]: *** [CMakeFiles/Makefile2:7798:
>> src/providers/pdal/CMakeFiles/provider_pdal.dir/all] Error 2
>> make: *** [Makefile:166: all] Error 2
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220321/0a00b1a9/attachment.html>
More information about the QGIS-Developer mailing list
