[QGIS-Developer] Override System Locale user interface with American English by Default?
Jürgen E. Fischer jef at norbit.de
Thu Mar 24 09:48:59 PDT 2022
Hi Alexandre,
On Thu, 24. Mar 2022 at 11:11:50 +0000, Alexandre Neto via QGIS-Developer wrote:
> The European Portuguese translation is quite poor, with many errors and bad
> translations.
Are there more that poor translations above 35%?
Otherwise I would suggest to fix the portuguese translation instead - if
everything else fails by removing the bad ones and getting it below threshold.
Or is resetting it the better choice?  That's will also get you C / en_US (or
pt_BR in this case?).
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220324/147f44fc/attachment.sig>
More information about the QGIS-Developer mailing list
