[QGIS-Developer] compiling qgis 3.24.2 (release branch) fails against SIP 6.6.1
Saulteau Don sault.don at gmail.com
Wed May 4 14:52:21 PDT 2022
Trying to compile QGIS from the release-3_42 git branch (
https://github.com/qgis/QGIS/tree/release-3_24) and failing against SIP
6.6.1 on Linux.
Here's the error for the relevant files:
[ 75%] Generating core/build/_core/sip_corepart0.cpp,
> core/build/_core/sip_corepart1.cpp, core/build/_core/sip_corepart2.cpp,
> core/build/_core/sip_corepart3.cp
> p, core/build/_core/sip_corepart4.cpp, core/build/_core/sip_corepart5.cpp,
> core/build/_core/sip_corepart6.cpp, core/build/_core/sip_corepart7.cpp,
> core/build/_
> core/sip_corepart8.cpp, core/build/_core/sip_corepart9.cpp,
> core/build/_core/sip_corepart10.cpp, core/build/_core/sip_corepart11.cpp,
> part12.cpp, core/build/_core/sip_corepart13.cpp,
> core/build/_core/sip_corepart14.cpp, core/build/_core/sip_corepart15.cpp
> Querying qmake about your Qt installation...
> These bindings will be built: core.
> Generating the core bindings...
> sip-build:
> /build/qgis/src/build/python/core/auto_generated/qgscadutils.sip: line 135
> column 12: 'name' is unexpected
> /build/qgis/src/build/python/core/auto_generated/qgscadutils.sip: line 139
> column 5: '}' is unexpected
> /build/qgis/src/build/python/core/auto_generated/qgscadutils.sip: line 148
> column 1: '}' is unexpected
> /build/qgis/src/build/python/core/auto_generated/qgscolorscheme.sip: line
> 122 column 1: 1 arguments are needed but 2 are provided
> /build/qgis/src/build/python/core/core_auto.sip: line 102 column 6: 1
> /build/qgis/src/build/python/core/core_auto.sip: line 169 column 18: 1
> /build/qgis/src/build/python/core/auto_generated/qgsfeaturerequest.sip:
> line 982 column 1: 1 arguments are needed but 2 are provided
> /build/qgis/src/build/python/core/core_auto.sip: line 85 column 50: 1
> /build/qgis/src/build/python/core/core_auto.sip: line 148 column 30: 1
> /build/qgis/src/build/python/core/core_auto.sip: line 77 column 28: 1
> /build/qgis/src/build/python/core/auto_generated/qgsmaplayer.sip: line
> 1988 column 1: 1 arguments are needed but 2 are provided
> 1990 column 1: 1 arguments are needed but 2 are provided
> /build/qgis/src/build/python/core/core_auto.sip: line 1992 column 17918: 1
> /build/qgis/src/build/python/core/core_auto.sip: line 240 column 10: 1
> /build/qgis/src/build/python/core/core_auto.sip: line 69 column 14: 1
> /build/qgis/src/build/python/core/auto_generated/qgsmargins.sip: line 130
> /build/qgis/src/build/python/core/auto_generated/qgsmargins.sip: line 132
> /build/qgis/src/build/python/core/auto_generated/qgsmargins.sip: line 134
> /build/qgis/src/build/python/core/auto_generated/qgsmargins.sip: line 136
> /build/qgis/src/build/python/core/auto_generated/qgsmargins.sip: line 138
> /build/qgis/src/build/python/core/auto_generated/qgsmargins.sip: line 140
> /build/qgis/src/build/python/core/auto_generated/qgsmargins.sip: line 142
> /build/qgis/src/build/python/core/auto_generated/qgsmargins.sip: line 144
> /build/qgis/src/build/python/core/auto_generated/qgsmargins.sip: line 146
> /build/qgis/src/build/python/core/auto_generated/qgsmargins.sip: line 148
> /build/qgis/src/build/python/core/auto_generated/qgsrenderedfeaturehandlerinterface.sip:
> line 48 column 1: '%Docstring' is unexpected
> line 74 column 5: 'virtual' is unexpected
> /build/qgis/src/build/python/core/core_auto.sip: line 486 column 26: 1
> /build/qgis/src/build/python/core/core_auto.sip: line 227 column 44: 1
> /build/qgis/src/build/python/core/core_auto.sip: line 335 column 7: 1
> /build/qgis/src/build/python/core/core_auto.sip: line 253 column 43: 1
> /build/qgis/src/build/python/core/auto_generated/qgstaskmanager.sip: line
> 303 column 1: 1 arguments are needed but 2 are provided
> /build/qgis/src/build/python/core/auto_generated/qgsvectorfilewriter.sip:
> line 725 column 1: 1 arguments are needed but 2 are provided
> /build/qgis/src/build/python/core/core_auto.sip: line 727 column 46: 1
> /build/qgis/src/build/python/core/core_auto.sip: line 106 column 49: 1
> /build/qgis/src/build/python/core/core_auto.sip: line 208 column 25: '.'
> is unexpected
> make[2]: ***
> [python/CMakeFiles/python_module_qgis__core.dir/build.make:773:
> python/core/build/_core/sip_corepart0.cpp] Error 1
> make[1]: *** [CMakeFiles/Makefile2:10144:
> python/CMakeFiles/python_module_qgis__core.dir/all] Error 2
> make: *** [Makefile:166: all] Error 2
Donovan
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220504/456adea5/attachment.htm>
More information about the QGIS-Developer mailing list
