[QGIS-Developer] Add algorithm to an existing provider?
Raymond Nijssen r.nijssen at terglobo.nl
Thu May 12 23:15:08 PDT 2022
Is there a way to add a processing algorithm to an existing provider
using pyqgis?
I have 2 plugins and don't know if they are both installed (or which one
will load first). The both contain processing algorithms and I want
those to end up in the same group.
Documentation is a bit brief on this:
QgsProcessingProvider
Examples show to put the addAlgorithm() function(s) in the
loadAlgorithms() function. Then calling
QgsApplication.processingRegistry().addProvider(provider)
adds the group (=provider?) and the algorithms are in it.
What I want to do is finding the provider if it exists already:
self.provider = QgsApplication.processingRegistry().providerById('test')
if self.provider is None:
     self.provider = RayProvider()
and then:
self.provider.addAlgorithm(TestAlgorithm2())
This doesn't work, neither when doing:
provider.refreshAlgorithms()
provider.load()
provider.loadAlgorithms()
I'm currently trial-and-errorring my way through this, but I hope
someone has a hint. Even someone pointing at 2 plugins working like this
would be very welcome!
Kind regards,
Raymond
More information about the QGIS-Developer mailing list
