[QGIS-Developer] import 3d or _3d in python?
Raymond Nijssen r.nijssen at terglobo.nl
Sun Oct 2 23:57:42 PDT 2022
While trying to import a 3D class in a python script, I found out that
the code in the pyqgis docs is not working (for me):
from qgis.3d import QgsLayoutItem3DMap
Instead I need to add an underscore for the 3d module name:
from qgis._3d import QgsLayoutItem3DMap
Should this be fixed in the documentation? I'm not all sure, cause when
trying to fix it, I found this related commit:
https://github.com/qgis/pyqgis/commit/1ac564790aa0b7abbd003c04d07358d8e4f14493
This is the page in the docs:
https://qgis.org/pyqgis/master/3d/QgsLayoutItem3DMap.html
Should I make an issue? It took me a while to figure out that _3d solution.
Cheers,
Raymond
More information about the QGIS-Developer mailing list
