[QGIS-Developer] import 3d or _3d in python?
Martin Dobias wonder.sk at gmail.com
Mon Oct 3 01:24:32 PDT 2022
Hi Raymond
The general idea is that for every PyQGIS module (e.g. "core") there is a
compiled python module (e.g. _core.so) and a directory acting as a module
("core") which imports the compiled module and adds some extra
functionality (docstrings and more). So normally one wants to use import
qgis.core instead of qgis._core.
Now with the 3d module things are not so great, because "3d" is not a valid
module name because of the leading digit, so import qgis.3d simply won't
work. There are some ways to work it around [1], but I wouldn't recommend
using them. But as stated earlier, importing qgis._3d should generally do
the job.
It is probably worth creating a ticket to address this, but I am not sure
how to best fix it - probably the whole module should be renamed so avoid
the leading digit - e.g. "threed"
[1]
https://stackoverflow.com/questions/9090079/in-python-how-to-import-filename-starts-with-a-number
Cheers
Martin
On Mon, Oct 3, 2022 at 8:58 AM Raymond Nijssen via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> While trying to import a 3D class in a python script, I found out that
> the code in the pyqgis docs is not working (for me):
> from qgis.3d import QgsLayoutItem3DMap
> Instead I need to add an underscore for the 3d module name:
> from qgis._3d import QgsLayoutItem3DMap
> Should this be fixed in the documentation? I'm not all sure, cause when
> trying to fix it, I found this related commit:
> https://github.com/qgis/pyqgis/commit/1ac564790aa0b7abbd003c04d07358d8e4f14493
> This is the page in the docs:
> https://qgis.org/pyqgis/master/3d/QgsLayoutItem3DMap.html
> Should I make an issue? It took me a while to figure out that _3d solution.
> Cheers,
> Raymond
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221003/17852878/attachment.htm>
More information about the QGIS-Developer mailing list
