[QGIS-Developer] QgsProcessingLayerPostProcessorInterface and Layers Legend Icon
C Hamilton adenaculture at gmail.com
Tue Oct 4 05:15:14 PDT 2022
I have several plugin functions that are
using QgsProcessingLayerPostProcessorInterface to style the layer after it
is created in a processing algorithm. I have largely ignored the fact that
after I style it, the legend displayed in the layers panel is its old style
and not the new one. I have a solution, but don't know if I am violating
some thread safe rule. I know I cannot use iface in the algorithm, but is
it safe to use in QgsProcessingLayerPostProcessorInterface?
In the top of my algorithm I import the following:
from qgis.utils import iface
In the processAlgorithm function I have the following.
if context.willLoadLayerOnCompletion(dest_id):
context.layerToLoadOnCompletionDetails(dest_id).setPostProcessor(StylePostProcessor.create(settings.lineColor,
settings.fontColor))
return {self.PrmOutput: dest_id}
My QgsProcessingLayerPostProcessorInterface looks like this. Notice the
line iface.layerTreeView().refreshLayerSymbology(layer.id()) which
effectively does what I need it to do. It works, but is safe or is there a
better way to do this? The output layer is a polygon in which I only want
the outline displayed. I am passing some color parameters from
processAlgorithm.
class StylePostProcessor(QgsProcessingLayerPostProcessorInterface):
    instance = None
    line_color = None
    font_color = None
    def __init__(self, line_color, font_color):
        self.line_color = line_color
        self.font_color = font_color
        super().__init__()
    def postProcessLayer(self, layer, context, feedback):
        if not isinstance(layer, QgsVectorLayer):
            return
        sym = layer.renderer().symbol().symbolLayer(0)
        sym.setBrushStyle(Qt.NoBrush)
        sym.setStrokeColor(self.line_color)
       * iface.layerTreeView().refreshLayerSymbology(layer.id
<http://layer.id>())*
    # Hack to work around sip bug!
    @staticmethod
    def create(line_color, font_color) -> 'StylePostProcessor':
        Returns a new instance of the post processor, keeping a reference
to the sip
        wrapper so that sip doesn't get confused with the Python subclass
and call
        the base wrapper implementation instead... ahhh sip, you wonderful
piece of sip
        StylePostProcessor.instance = StylePostProcessor(line_color,
font_color)
        return StylePostProcessor.instance
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221004/e4556e5f/attachment.htm>
More information about the QGIS-Developer mailing list
