[QGIS-Developer] QGIS Upgrade/Update Inquiry
Andreas Neumann a.neumann at carto.net
Wed Oct 5 22:42:30 PDT 2022
Hi John,
Hi John,
For professional use we normally recommend the LTR releases (once they
become LTR after 4 months): 3.22 is now LTR, 3.28 will be LTR in
february next year. Every third release (3.22, 3.28, 3.34) will become
LTR 4 months after the initial release.
See also
https://www.qgis.org/en/site/getinvolved/development/roadmap.html#release-schedule
--> look for the "Long-Term Repo" column.
.0 and partially also .1 releases are not recommended for production use
unless you are willing to take risks and/or want to help testing.
Helping testing is always appreciated. Ideally testing would be done
already with nightly builds before the releases.
Greetings,
Andreas
On 2022-10-06 04:37, John Bingco via QGIS-Developer wrote:
> Hey Alex,
> Sorry I forgot to respond to the first part of your email.
> The client currently uses version 3.16, are we good to install 3.26 or
> should we go to 3.22 LTR?
> Regards,
> John
> From: Alexandre Neto <senhor.neto at gmail.com>
> Sent: Wednesday, 5 October 2022 11:17 PM
> To: John Bingco <john.bingco at elevate.com.au>
> Cc: qgis-dev <qgis-developer at lists.osgeo.org>
> Subject: Re: [QGIS-Developer] QGIS Upgrade/Update Inquiry
> Hi,
> It's important to know what is the current version you are using and
> what is the version you want to update to. I would suggest using 3.22
> LTR.
> Nevertheless, both 3.22 LTR and 3.26 versions should be retro
> compatible with most 3.x versions.
> Best regards
> Alexandre Neto
> User support
> www.qcooperative.net [3]
> A quarta, 5/10/2022, 06:22, John Bingco via QGIS-Developer
> <qgis-developer at lists.osgeo.org> escreveu:
>> Hi Team,
>> I work for an IT service provider in Australia and we are working with
>> a client that uses QGIS.
>> The client is requesting for their QGIS to be updated/upgraded to the
>> latest version. Just wanted to check if there is anything we need to
>> take note when doing the update/upgrade. User is worried about
>> compatibility issues.
>> If there is none, are we good to just directly install the latest
>> version on server for all users to have updated version of the
>> software?
>> Appreciate your response on this. 😊
>> Regards,
>> John
>> John Bingco
>> TECHNICIAN
>> _ELEVATE TECHNOLOGY_
>> Mackay, Brisbane, & Newcastle
>> P:
>> 1300 463 538
>> W:
>> www.elevate.com.au [1]
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer [2]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> [2]
Links:
[1] https://www.elevate.com.au/
[2] https://lists.osgeo.org/mailman/listinfo/qgis-developer
[3] http://www.qcooperative.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221006/16284028/attachment.htm>
More information about the QGIS-Developer mailing list
