[QGIS-Developer] Tests & Merge Request
Sandro Santilli strk at kbt.io
Thu Oct 6 03:44:07 PDT 2022
On Sun, Sep 11, 2022 at 02:58:23PM +0100, Tim Sutton via QGIS-Developer wrote:
> I believe this is normal.
I believe this is NOT normal. It may be "expected" (ie: we all know
about this problem), but that doesn't make it normal.
Normal is for a testing framework to actually only fail if a bug is
introduced by a modification and succeed otherwise.
I would incourage people who get failures when running tests to file
tickets, as a very first step to reach that state.
> On Sun, Sep 11, 2022 at 11:17 AM Nicolas Godet via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
> > Same « issue » here where I have a lot of failed test locally.
--strk;
More information about the QGIS-Developer mailing list
