[QGIS-Developer] QGIS Upgrade/Update Inquiry
Alexandre Neto senhor.neto at gmail.com
Wed Oct 5 06:17:26 PDT 2022
It's important to know what is the current version you are using and what
is the version you want to update to. I would suggest using 3.22 LTR.
Nevertheless, both 3.22 LTR and 3.26 versions should be retro compatible
with most 3.x versions.
Best regards
Alexandre Neto
User support
www.qcooperative.net
A quarta, 5/10/2022, 06:22, John Bingco via QGIS-Developer <
qgis-developer at lists.osgeo.org> escreveu:
> Hi Team,
> I work for an IT service provider in Australia and we are working with a
> client that uses QGIS.
> The client is requesting for their QGIS to be updated/upgraded to the
> latest version. Just wanted to check if there is anything we need to take
> note when doing the update/upgrade. User is worried about compatibility
> issues.
> If there is none, are we good to just directly install the latest version
> on server for all users to have updated version of the software?
> Appreciate your response on this. 😊
> Regards,
> John
> John Bingco  TECHNICIAN
> ELEVATE TECHNOLOGY
> Mackay, Brisbane, & Newcastle
> P:  1300 463 538
> W:  *www.elevate.com.au* <https://www.elevate.com.au/>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221005/954f211e/attachment-0001.htm>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221005/954f211e/attachment-0002.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221005/954f211e/attachment-0003.gif>
More information about the QGIS-Developer mailing list
