[QGIS-Developer] Import DWG\DXF use curves option
Alexandre Neto senhor.neto at gmail.com
Mon Oct 10 08:37:07 PDT 2022
Yes, I believe so.
My linestrings are also simple, now rounded corners, but it still promotes
it to compoundcurves, which is them harder to import to PostGIS.
I have ended up using ogr2ogr with the option
-nlt CONVERT_TO_LINEAR
A segunda, 10/10/2022, 16:29, Richard Duivenvoorde <rdmailings at duif.net>
escreveu:
> On 10/10/22 17:11, Alexandre Neto via QGIS-Developer wrote:
> > Hi,
> > Not sure of a feature or a bug, but shouldn't disabling the "use curves"
> in the Import DWG\DXF tool output non-compound curve geometries?
> > I am getting curves even with the option turned of.
> Mmm, seeing this message... could the following be maybe related?
> Recently I created a Polygon with a hole, and copied one feature (WKT
> output), and also was presented with a 'CompoundCurve' part in it (while
> all was square)...
> MultiPolygon (((6.13102839454553816 52.75093214925507823,
> 6.130964672425808 52.74717640996099277, 6.14539911649133597
> 52.7466899769035038, 6.14536915982601872 52.75123707754761426,
> 6.13102839454553816 52.75093214925507823), CompoundCurve
> ((6.13427151349723498 52.75005518140639538, 6.13467440942566444
> 52.7482075319318966, 6.14346286447305268 52.7477566482503093,
> 6.14241109067726665 52.74974024139419271, 6.13427151349723498
> 52.75005518140639538))))
> For reference: I created a quick MultiPolygon type Memory layer, as 2
> rectangles(!)
> This is above feature as GeoJson:
> {"features":[{"bbox":[6.130965,52.74669,6.145399,52.751237],"geometry":{"coordinates":[[[[6.131028,52.750932],[6.130965,52.747176],[6.145399,52.74669],[6.145369,52.751237],[6.131028,52.750932]],[[6.134272,52.750055],[6.134674,52.748208],[6.143463,52.747757],[6.142411,52.74974],[6.134272,52.750055]]]],"type":"MultiPolygon"},"id":-9,"properties":null,"type":"Feature"}],"type":"FeatureCollection"}
> Could this be related?
> Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221010/66f605a5/attachment.htm>
More information about the QGIS-Developer mailing list
