[QGIS-Developer] pyqgis labelling settings
Francisco Puga fpuga at icarto.es
Sun Oct 23 02:11:22 PDT 2022
This should work when working with SingleLabels
layer = iface.activeLayer()
settings = layer.labeling().settings()
textFormat = settings.format()
textFormat.setSize(20);
settings.setFormat(textFormat)
layer.labeling().setSettings(settings)
hope it helps
El vie, 21 oct 2022 a las 18:18, Hugh Kelley via QGIS-Developer
(<qgis-developer at lists.osgeo.org>) escribió:
> Hi,
> I'm hoping to make some scripts for labelling layers.
> I've found the basic labelling settings in
>     layer = iface.activeLayer()layer.labeling().settings().format().size()
> for example, and it seems that I could be able to update that with an object like
>     newsize = QgsTextFormat()
>     newsize.setSize(20)
> but I haven't yet found the correct way to update the layer's value.
> it seems like it needs to be passed an entire new `QgsPalLayerSettings` object but I haven't found a way to build a complete object.
> I've seen `readFromLayer()` but I'm guessing that was a version 2 method that's no longer available in version 3.
> any pointers or a simple piece of code for updating a layer labelling property would be hugely appreciated.
> it also occurs to me to ask whether there is anything like:
>     print(layer.renderer().symbol().symbolLayers()[0].properties())
> that returns a dict of the layer symbology properties for a label.
> Another helpful thing would be code that imports a label definition from an exported xml file.
> thanks,
> hugh
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Francisco Puga
iCarto | Innovación, Cooperación, Cartografía y Territorio S.L.
https://icarto.es
c/ Rafael Alberti nº 13 – 1º D
15008 A Coruña
Galicia (Spain)
+34 881927808
Este correo electrónico contiene información estrictamente
confidencial y es de uso exclusivo del destinatario, quedando
prohibida a cualquier otra persona su revelación, copia, distribución,
o el ejercicio de cualquier acción relativa a su contenido. Si ha
recibido este mensaje por error, por favor conteste a su remitente
mediante correo electrónico y proceda a borrarlo de su sistema.
Sus datos personales serán tratados de forma confidencial y no serán
cedidos a terceros ajenos a ICARTO. En cualquier caso, podrá ejercer
los derecho de oposición, acceso, rectificación y cancelación de
acuerdo con lo establecido en la Ley Orgánica 15/99, de 13 de
diciembre, de Protección de Datos de Carácter Personal dirigiéndose a
Innovación, Cooperación, Cartografía e Territorio, SL. (ICARTO) en la
dirección postal a C/ Rafael Alberti, nº 13, 1ºD, 15.008 – (A Coruña).
More information about the QGIS-Developer mailing list
