[QGIS-Developer] Vector destination vs feature sink
Anita Graser anitagraser at gmx.at
Sun Oct 23 04:42:56 PDT 2022
Thank you very much, Thomas. This code comparison approach is very useful indeed.
If FeatureSink covers all functions of VectorDestination and more, that still leaves me wonder what is the downside of a FeatureSink
"Note: Consider using the more flexible QgsProcessingParameterFeatureSink wherever possible."
i.e. where is it not possible to use a Feature Sink? Only in older versions of QGIS?
Regards,
Anita
On Saturday, 22. October 2022 23:32:11 (+02:00), Thomas Gratier wrote:
Although, I do know the intend to recommend one against the other, doing some code differences helps to sort out things.
They both inherits from same classes but the constructor for QgsProcessingParameterFeatureSink accepts an additionnal arg bool supportsAppend=false
You also find the additional methods in QgsProcessingParameterFeatureSink to manipulate the same supportsAppend.
a = QgsProcessingParameterVectorDestination(
  'OUTPUT',
  'Sortie'
b = QgsProcessingParameterFeatureSink(
  'OUTPUT',
  'Sortie'
methods_a = dir(a)
methods_b = dir(b)
common_methods = set(methods_a).intersection(methods_b)
print(common_methods)
only_in_a = set(methods_a).difference(methods_b)
print(only_in_a)
only_in_b = set(methods_b).difference(methods_a)
print(only_in_b)
Regards
Thomas Gratier
Le ven. 21 oct. 2022 à 18:07, Anita Graser via QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
Thank you Stefan,
I saw that note but was hoping some developer could shed light on what they mean by "more flexible" and "wherever possible". I guess otherwise it's just trial and error.
Regards,
Anita
On Wednesday, 19. October 2022 07:44:05 (+02:00), Stefan Giese (WhereGroup) wrote:
Hi Anita,
they are very similar, but the API Documentation says to QgsProcessingParameterVectorDestination: "Note: Consider using the more flexible QgsProcessingParameterFeatureSink wherever possible." (https://api.qgis.org/api/3.22/classQgsProcessingParameterVectorDestination.html#details)
Best regards
Stefan
Am 18.10.2022 um 20:35 schrieb Anita Graser via QGIS-Developer:
Hi.
Does any one of you know the real difference between QgsProcessingParameterVectorDestination versus QgsProcessingParameterFeatureSink? They seem to be used interchangably in the resources I can find.
Thank you.
Anita
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Anita Graser
Home: http://anitagraser.com
Twitter: @underdarkgis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221023/beb88a67/attachment-0001.htm>
More information about the QGIS-Developer mailing list
