[QGIS-Developer] segmentation fault in standalone script using PyQGIS
Mélanie Dol Melanie.Dol at sat-ocean.com
Thu Oct 27 07:34:06 PDT 2022
Hi all,
I'm developing a standalone script in Python, using QGIS libraires. My
goal is to apply a style to my geopackage and save it without opening QGIS.
Before to write a standalone script, I tested my script in the python
console of QGIS and it works.
Now, I'm trying to run it in using PYQGIS in standalone script and
obvioulsy it doesn't work.
When I'm trying to save my layers with processing.run, a segmentation
fault appears. Do you have any idea what is going on ? Please find
attached my script and the QGIS version .
*python3.8 Create_Style_QGIS.py*
/usr/share/qgis/python/plugins/processing/algs/qgis/ImportIntoSpatialite.py:103:
SyntaxWarning: "is" with a literal. Did you mean "=="?
   if uri.database() is '':
/usr/share/qgis/python/plugins/processing/algs/qgis/SpatialiteExecuteSQL.py:69:
/usr/share/qgis/python/plugins/processing/algs/grass7/Grass7Utils.py:191:
   if path is '':
Segmentation fault (core dumped)
Many thanks and regards,
Mélanie Dol
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221027/b2651db9/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221027/b2651db9/attachment-0001.png>
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221027/b2651db9/attachment-0001.py>
More information about the QGIS-Developer mailing list
