[QGIS-Developer] OSGEO4W nightlies broken?
i-s-o 46.i.s.o.64 at gmail.com
Fri Sep 2 04:16:59 PDT 2022
Not sure if it is a similar issue: 3.22 and 3.26 nightlies got updated
today, but the latest 3.27 update is from August 22.
On Thu, Aug 11, 2022, 02:46 Jürgen E. Fischer via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi Nyall,
> On Thu, 11. Aug 2022 at 14:51:16 +1000, Nyall Dawson via QGIS-Developer
> wrote:
> > It looks like the osgeo4w qgis dev releases are stuck with an ~10 day
> > old build right now. Is this a known issue? Or something broken on the
> > osgeo4w infrastructure?
> Another unique_ptr template issue:
> C:/PROGRA~2/MICROS~3/2019/COMMUN~1/VC/Tools/MSVC/1429~1.300/bin/Hostx64/x64/cl.exe
> /nologo /TP -DNOMINMAX -DQT_CONCURRENT_LIB -DQT_CORE_LIB
> -DQT_DEPRECATED_WARNINGS -DQT_DISABLE_DEPRECATED_BEFORE=0x050800
> -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_NO_CAST_TO_ASCII -DQT_NO_DEBUG
> -DQT_NO_FOREACH -DQT_POSITIONING_LIB -DQT_PRINTSUPPORT_LIB
> -DQT_SERIALPORT_LIB -DQT_SQL_LIB -DQT_SVG_LIB -DQT_USE_QSTRINGBUILDER
> -DQT_WEBKITWIDGETS_LIB -DQT_WEBKIT_LIB -DQT_WIDGETS_LIB -DQT_XML_LIB
> -DSIP_VERSION=0x060101
> -DTEST_DATA_DIR=/"C:/src/OSGeo4W/src/qgis-dev/qgis/tests/testdata/"
> -DWITH_COPC -DWITH_EPT -DWITH_QTWEBKIT -D_CRT_NONSTDC_NO_WARNINGS
> -D_CRT_SECURE_NO_WARNINGS -D_HAS_AUTO_PTR_ETC=1 -D_HAVE_WINDOWS_H_
> -D_USE_MATH_DEFINES -Dqgis_core_EXPORTS
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/build/src/core/qgis_core_autogen/include
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/external/poly2tri
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/providers/ept
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/providers/copc
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/3d
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/annotations
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/auth
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/browser
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/callouts
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/classification
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/diagram
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/dxf
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/editform
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/effects
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/elevation
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/expression
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/externalstorage
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/fieldformatter
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/geometry
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/geocms
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/geocms/geonode
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/geocoding
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/gps
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/labeling
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/layertree
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/layout
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/locator
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/maprenderer
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/mesh
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/metadata
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/network
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/numericformats
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/pal
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/plot
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/pointcloud
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/pointcloud/expression
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/processing
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/processing/models
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/proj
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/project
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/providers/arcgis
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/providers/memory
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/providers/gdal
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/providers/ogr
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/providers/meshmemory
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/raster
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/renderer
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/scalebar
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/settings
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/symbology
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/textrenderer
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/validity
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/vector
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/src/core/vectortile
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/external/nlohmann
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/external/kdbush/include
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/external/nmea
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/external/rtree/include
> -IC:/src/OSGeo4W/src/qgis-dev/qgis/external/meshOptimizer
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/include
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtCore
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/./mkspecs/win32-msvc
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtGui
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtANGLE
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtXml
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtWidgets
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtSvg
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtPrintSupport
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtNetwork
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtSql
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtConcurrent
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/gdal-dev/include
> -IC:/src/osgeo4w/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtCrypto
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/qt5keychain
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtSerialPort
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtWebKitWidgets
> -IC:/src/OSGeo4W/src/qgis-dev/osgeo4w/osgeo4w/apps/Qt5/include/QtPositioning
> /DWIN32 /D_WINDOWS /W3 /GR /EHsc  /wd4091  /wd4100  /wd4127  /wd4190
> /wd4231  /wd4244  /wd4251  /wd4267  /wd4275  /wd4290  /wd4456  /wd4457
> /wd4458  /wd4505  /wd4510  /wd4512  /wd4610  /wd4706  /wd4714  /wd4800
> /wd4996  /utf-8 /std:c++17 /MD /Z7 /MP /Od /D NDEBUG -std:c++17
> /showIncludes
> /Fosrc/core/CMakeFiles/qgis_core.dir/qgis_core_autogen/mocs_compilation.cpp.obj
> /Fdsrc/core/CMakeFiles/qgis_core.dir/ /FS -c
> C:/src/OSGeo4W/src/qgis-dev/osgeo4w/build/src/core/qgis_core_autogen/mocs_compilation.cpp
> C:\Program Files (x86)\Microsoft Visual
> Studio\2019\Community\VC\Tools\MSVC\14.29.30037\include\deque(1176): error
> C2280:
> 'std::unique_ptr<QgsProviderSublayerModelNode,std::default_delete<QgsProviderSublayerModelNode>>
> &std::unique_ptr<QgsProviderSublayerModelNode,std::default_delete<QgsProviderSublayerModelNode>>::operator
> =(const
> &)': attempting to reference a deleted function
> Studio\2019\Community\VC\Tools\MSVC\14.29.30037\include\memory(3270): note:
> see declaration of
> 'std::unique_ptr<QgsProviderSublayerModelNode,std::default_delete<QgsProviderSublayerModelNode>>::operator
> =(const
> &)': function was explicitly deleted
> Studio\2019\Community\VC\Tools\MSVC\14.29.30037\include\deque(875): note:
> see reference to function template instantiation 'void
> std::deque<std::unique_ptr<QgsProviderSublayerModelNode,std::default_delete<QgsProviderSublayerModelNode>>,std::allocator<std::unique_ptr<QgsProviderSublayerModelNode,std::default_delete<QgsProviderSublayerModelNode>>>>::assign<std::_Deque_unchecked_const_iterator<std::_Deque_val<std::_Deque_simple_types<_Ty>>>,0>(_Iter,_Iter)'
> being compiled
>         with
> _Ty=std::unique_ptr<QgsProviderSublayerModelNode,std::default_delete<QgsProviderSublayerModelNode>>,
> _Iter=std::_Deque_unchecked_const_iterator<std::_Deque_val<std::_Deque_simple_types<std::unique_ptr<QgsProviderSublayerModelNode,std::default_delete<QgsProviderSublayerModelNode>>>>>
> being compiled
>         with
> Studio\2019\Community\VC\Tools\MSVC\14.29.30037\include\deque(873): note:
> while compiling class template member function 'void
> std::deque<std::unique_ptr<QgsProviderSublayerModelNode,std::default_delete<QgsProviderSublayerModelNode>>,std::allocator<std::unique_ptr<QgsProviderSublayerModelNode,std::default_delete<QgsProviderSublayerModelNode>>>>::_Copy_assign(const
> &,std::false_type)'
> Studio\2019\Community\VC\Tools\MSVC\14.29.30037\include\deque(889): note:
> &,std::false_type)' being compiled
> C:/src/OSGeo4W/src/qgis-dev/osgeo4w/build/src/core/qgis_core_autogen/BS6B2UBKRC/../../../../../../qgis/src/core/providers/qgsprovidersublayermodel.h(331):
> note: see reference to class template instantiation
> 'std::deque<std::unique_ptr<QgsProviderSublayerModelNode,std::default_delete<QgsProviderSublayerModelNode>>,std::allocator<std::unique_ptr<QgsProviderSublayerModelNode,std::default_delete<QgsProviderSublayerModelNode>>>>'
> being compiled
> The build logs are uploaded to dash, but for some reason not visible - but
> that's nothing new.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220902/5aaa0d65/attachment-0001.htm>
More information about the QGIS-Developer mailing list
