[QGIS-Developer] Tests & Merge Request
Nicolas Godet nicolas.godet at outlook.fr
Sun Sep 11 03:17:50 PDT 2022
Same « issue » here where I have a lot of failed test locally.
Mostly visual render that slightly differs from expected image.
Linux Mint Vanessa (Ubuntu 22.04)
4K TV screen
A lot of timeout too or aborted child
Le 10 sept. 2022 à 11:08, Marc Ducobu via QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
Hi !
I'm working on a Merge Request ( https://github.com/qgis/QGIS/pull/50167 ) and when I run the tests locally, some tests failed. It seems not to be linked with my modifications : when I run the tests without my changes the same tests failed too.
I run the tests using the command `make test' or `make check`in my build-master directory.
In my ccmake config, I have :
ENABLE_TESTS                     ON
and also
 ENABLE_COVERAGE                  OFF
 ENABLE_HANATEST                  OFF
 ENABLE_LOCAL_BUILD_SHORTCUTS     OFF
 ENABLE_MODELTEST                 OFF
 ENABLE_MSSQLTEST                 OFF
 ENABLE_MSSQLTEST_CPP             OFF
 ENABLE_ORACLETEST                OFF
 ENABLE_PGTEST                    OFF
ENABLE_SAGA_TESTS          OFF
The tests that failed are :
2 - checkGitStatus (Failed)
24 - ProcessingOtbAlgorithmsTest (Failed)
46 - test_core_compositionconverter (Failed)
99 - test_core_layoutmanualtable (Failed)
107 - test_core_layoutpicture (Failed)
111 - test_core_layouttable (Failed)
219 - test_core_openclutils (Subprocess aborted)
220 - test_core_coordinatereferencesystem (Failed)
268 - test_gui_scalecombobox (Failed)
270 - test_gui_rangewidgetwrapper (Failed)
275 - test_gui_filedownloader (Subprocess aborted)
293 - test_gui_queryresultwidget (Subprocess aborted)
297 - test_3d_3drendering (Failed)
307 - test_analysis_processingalgspt2 (Failed)
310 - test_analysis_rastercalculator (Failed)
323 - test_provider_wcsprovider (Failed)
339 - test_app_advanceddigitizing (Failed)
341 - test_app_applocatorfilters (Failed)
395 - PyQgsAnnotation (Failed)
427 - PyQgsColorRampLegendNode (Failed)
453 - PyQgsDistanceArea (Failed)
466 - PyQgsExternalStorageWebDAV (Failed)
503 - PyQgsGraduatedSymbolRenderer (Failed)
530 - PyQgsLayoutExporter (Failed)
594 - PyQgsMetadataUtils (Failed)
606 - PyQgsNumericFormat (Failed)
612 - PyQgsOgcUtils (Failed)
625 - PyQgsPlot (Failed)
664 - PyQgsProviderSublayerModel (Failed)
700 - PyQgsScaleWidget (Failed)
709 - PyQgsTextRenderer (Failed)
757 - PyQgsVectorLayerCache (Failed)
774 - PyQgsWFSProviderGUI (Failed)
794 - PyQgsSelectiveMasking (Failed)
801 - PyQgsPalLabelingServer (Failed)
812 - PyQgsServerWMSGetMap (Failed)
817 - PyQgsServerWMSGetLegendGraphic (Failed)
826 - PyQgsServerSecurity (Timeout)
845 - PyQgsServerConfigCache (Timeout)
What should I do for not having tests that failed ?
Also is it possible to run a single test ?
Thanks a lot for your time & held.
Marc
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220911/de223626/attachment.htm>
More information about the QGIS-Developer mailing list
