[QGIS-Developer] Tests & Merge Request
Julien Cabieces
julien.cabieces at oslandia.com
Mon Sep 12 00:02:40 PDT 2022
There is also a recent script file that will help you run the tests in
Docker just like on CI:
https://github.com/qgis/QGIS/blob/master/.ci/run_tests.sh
Regards,
Julien
> I believe this is normal. If you want to run tests locally you should use
> the docker toolchain like the GitHub action uses (or set up similar actions
> in your fork). See:
> https://github.com/qgis/QGIS/blob/master/.github/workflows/run-tests.yml
> Regards
> Tim
> On Sun, Sep 11, 2022 at 11:17 AM Nicolas Godet via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> Hi,
>> Same « issue » here where I have a lot of failed test locally.
>> Mostly visual render that slightly differs from expected image.
>> Linux Mint Vanessa (Ubuntu 22.04)
>> 4K TV screen
>> A lot of timeout too or aborted child
>> Le 10 sept. 2022 à 11:08, Marc Ducobu via QGIS-Developer <
>> qgis-developer at lists.osgeo.org> a écrit :
>> Hi !
>> I'm working on a Merge Request ( https://github.com/qgis/QGIS/pull/50167
>> ) and when I run the tests locally, some tests failed. It seems not to be
>> linked with my modifications : when I run the tests without my changes the
>> same tests failed too.
>> I run the tests using the command `make test' or `make check`in my
>> build-master directory.
>> In my ccmake config, I have :
>> ENABLE_TESTS ON
>> and also
>> ENABLE_COVERAGE OFF
>> ENABLE_HANATEST OFF
>> ENABLE_LOCAL_BUILD_SHORTCUTS OFF
>> ENABLE_MODELTEST OFF
>> ENABLE_MSSQLTEST OFF
>> ENABLE_MSSQLTEST_CPP OFF
>> ENABLE_ORACLETEST OFF
>> ENABLE_PGTEST OFF
>> ENABLE_SAGA_TESTS OFF
>> The tests that failed are :
>> 2 - checkGitStatus (Failed)
>> 24 - ProcessingOtbAlgorithmsTest (Failed)
>> 46 - test_core_compositionconverter (Failed)
>> 99 - test_core_layoutmanualtable (Failed)
>> 107 - test_core_layoutpicture (Failed)
>> 111 - test_core_layouttable (Failed)
>> 219 - test_core_openclutils (Subprocess aborted)
>> 220 - test_core_coordinatereferencesystem (Failed)
>> 268 - test_gui_scalecombobox (Failed)
>> 270 - test_gui_rangewidgetwrapper (Failed)
>> 275 - test_gui_filedownloader (Subprocess aborted)
>> 293 - test_gui_queryresultwidget (Subprocess aborted)
>> 297 - test_3d_3drendering (Failed)
>> 307 - test_analysis_processingalgspt2 (Failed)
>> 310 - test_analysis_rastercalculator (Failed)
>> 323 - test_provider_wcsprovider (Failed)
>> 339 - test_app_advanceddigitizing (Failed)
>> 341 - test_app_applocatorfilters (Failed)
>> 395 - PyQgsAnnotation (Failed)
>> 427 - PyQgsColorRampLegendNode (Failed)
>> 453 - PyQgsDistanceArea (Failed)
>> 466 - PyQgsExternalStorageWebDAV (Failed)
>> 503 - PyQgsGraduatedSymbolRenderer (Failed)
>> 530 - PyQgsLayoutExporter (Failed)
>> 594 - PyQgsMetadataUtils (Failed)
>> 606 - PyQgsNumericFormat (Failed)
>> 612 - PyQgsOgcUtils (Failed)
>> 625 - PyQgsPlot (Failed)
>> 664 - PyQgsProviderSublayerModel (Failed)
>> 700 - PyQgsScaleWidget (Failed)
>> 709 - PyQgsTextRenderer (Failed)
>> 757 - PyQgsVectorLayerCache (Failed)
>> 774 - PyQgsWFSProviderGUI (Failed)
>> 794 - PyQgsSelectiveMasking (Failed)
>> 801 - PyQgsPalLabelingServer (Failed)
>> 812 - PyQgsServerWMSGetMap (Failed)
>> 817 - PyQgsServerWMSGetLegendGraphic (Failed)
>> 826 - PyQgsServerSecurity (Timeout)
>> 845 - PyQgsServerConfigCache (Timeout)
>> What should I do for not having tests that failed ?
>> Also is it possible to run a single test ?
>> Thanks a lot for your time & held.
>> Marc
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
