[QGIS-Developer] Approval and Maintainer-Change of ORSTools-Plugin
Jakob Schnell Jakob.Schnell at heigit.org
Wed Apr 5 00:52:56 PDT 2023
Hey Tim,
yeah, it looks like that's the setting influencing the `Maintainer` entry in
the plugin details.
Could you change that to "heigit"?
That would be much appreciated.
Could the "heigit" user also get the `plugins.can_approve`-permission mentioned
in the docs¹? What would be the process to apply for said permission?
Best regards,
Jakob
[1]:
https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/plugins/releasing.html#permissions
On Tue, 4 Apr 2023 23:47:08 +0100
Tim Sutton <tim at kartoza.com> wrote:
> Hi Jakob
> These are the things I can edit in the admin panel. I suspect you want to
> change the 'created by' field? Please indicate the osgeo id of the person
> it should be changed to.
> Thanks
> Tim
> [image: image.png]
> On Tue, Apr 4, 2023 at 2:27 PM Jakob Schnell via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
> > Dear QGIS-devs,
> > not sure if this is the correct point of contact, but i couldn't find
> > any information about plugin approval and maintainer changes on
> > https://plugins.qgis.org/. Please redirect me, if this is the wrong
> > contact.
> > Our plugin (https://plugins.qgis.org/plugins/ORStools/) had a change in
> > the maintainer.
> > However there is no entry in the metadata.txt to change the maintainer
> > displayed in the Details tab.
> > I did search quite a bit but couldn't find any solution to remove
> > nilsnolde as a maintainer from the Details.
> > Is this probably saved somewhere internally on the website?
> > What would be the correct way to go about changing the maintainer?
> > Is the maintainer responsible for approving the plugin? If not, is there
> > anything that we can do to facilitate the process of approval?
> > Hope to hear from you.
> > Best regards,
> > Jakob
> > Jakob Schnell
> > HeiGIT gGmbH
> > Heidelberg Institute for Geoinformation Technology at Heidelberg University
> > https://heigit.org | jakob.schnell at heigit.org | phone +49-6221-533 482
> > Postal address: Schloss-Wolfsbrunnenweg 33 | 69118 Heidelberg | Germany
> > Offices: Berliner Str. 45 | 69120 Heidelberg | Germany
> > Amtsgericht Mannheim | HRB 733765
> > Managing Directors: Prof. Dr. Alexander Zipf | Dr. Gesa Schönberger
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Jakob Schnell
HeiGIT gGmbH
Name: Screenshot 2023-04-05 at 09-46-57 ORS Tools ? QGIS Python Plugins Repository.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230405/75ab9445/attachment-0001.png>
More information about the QGIS-Developer mailing list
