[QGIS-Developer] Custom functions does not automatically load
Stefan Giese (WhereGroup)
stefan.giese at wheregroup.com
Tue Apr 11 00:27:39 PDT 2023
an in addition to Hannes you should check the python expression folder
in your profile folder:
* goto "Settings"->"User Profiles"->"Open Active Profile Folder"
* and then check the subfolder \python\expressions
* there should be your python expression function as python file
Best regards
Stefan
C:\Users\stefa\AppData\Roaming\QGIS\QGIS3\profiles\Deutsch\python\expressions
Am 11.04.2023 um 09:10 schrieb Johannes Kröger (WhereGroup) via
QGIS-Developer:
> Hi Catania,
> please see the checklist of
> https://github.com/qgis/QGIS/blob/master/.github/ISSUE_TEMPLATE/10_bug_report.yml
> on what info is useful in a bug report. Did you try it in a new profile?
> Cheers, Hannes
> Am 11.04.23 um 02:37 schrieb Catania, Luke A ERDC-RDE-GRL-VA CIV via
> QGIS-Developer:
>> I wrote a custom function that accesses the area of the feature and
>> adjusts the label accordingly. After I clicked on Save and Load
>> Function I see my functions category and the functions and can use
>> them in the expression tab, but when I close QGIS and start it again,
>> the function is not automatically loaded. I have to go to the layer
>> properties and open the expression assigned in the label properties
>> and click Save and Load Function and select apply/ok. This is not
>> gonna work for me since I need this to work automatically so when I
>> create an installer for my software this function works for everyone.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230411/cab7f274/attachment.htm>
