[QGIS-Developer] Pygis: Processing algorithms not releasing file handles
Lauren Yang lauren.yang at blightanner.com.au
Thu Feb 2 17:48:22 PST 2023
Hello QGIS developers,
I have a problem where I am calling a processing algorithm with Python not releasing file handles.
The smallest reproducible code sample and work flow does the following:
  1.  Calls the native:rasterlayerzonalstatistics processing algorithm on a raster layer by adding it as a task through QgsApplication task manager
  2.  The callback is invoked as expected, the statistics file is generated
  3.  Remove the original layer in QGIS layers pane because you didn't like it/you want to do it again for whatever reason.  It seems to be removed successfully.
  4.  Now in file explorer, try to delete the layer file - get "file in use" error that won't go away until  you close QGIS
I see on stackoverflow this is intermittently reported https://gis.stackexchange.com/questions/433300/deleting-folder-and-processed-files-in-qgis-using-pyqgis and https://gis.stackexchange.com/questions/243520/deleting-raster-file-after-doing-some-processing-in-qgis but have only seen workarounds.
The files for the QGIS workspace that reproduces the problem is uploaded here: [?Folder icon]  QGISProcessingFileHandles<https://blightanner-my.sharepoint.com/:f:/g/personal/lauren_yang_blightanner_com_au/EvQ-xHtnXINFigK0FutFjngBxGKOlOB7M8pKVNYTAX4d5Q?e=sn9geF>  To reproduce the problem, in the python console of QGIS type exec(open('processFileSnippet.py').read())
I'm not sure if I'm not calling the processing algorithm correctly or not closing file handles when I should be.  If the link above doesn't work, I can provide the python file snippet and supporting raster file.
Other details -  OS: Windows 10 64 bit, QGIS version 3.22.5, Python 3.9.5
Any insight would be appreciated.
Thanks,
Lauren
Lauren Yang
Civil and Water Engineer
[cid:image001.jpg at 01D937C2.FCC321D0]<https://blightanner.com.au/>
Brisbane +61 7 3251 8555
Sydney +61 2 9170 3777
Direct +61 7 3251 8555
[cid:image002.png at 01D937C2.FCC321D0][cid:image003.png at 01D937C2.FCC321D0]<https://www.linkedin.com/company/1818291>[cid:image004.png at 01D937C2.FCC321D0]<https://www.instagram.com/blightanner/>[cid:image005.png at 01D937C2.FCC321D0]<https://blightanner.com.au/>
[nov Template1.png]<https://blightanner.com.au/news-article/tasmanian-cultural-hub-the-hedberg-wins-international-architecture-award/>
ISO9001 Quality Approved JAS-ANZ
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230203/c4d70511/attachment-0001.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230203/c4d70511/attachment-0001.jpg>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230203/c4d70511/attachment-0006.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230203/c4d70511/attachment-0007.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230203/c4d70511/attachment-0008.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230203/c4d70511/attachment-0009.png>
Type: image/png
Desc: image006.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230203/c4d70511/attachment-0010.png>
Type: image/png
Desc: image007.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230203/c4d70511/attachment-0011.png>
More information about the QGIS-Developer mailing list
