[QGIS-Developer] PyQGIS code: setting filter expression for value relation widget
Andreas Neumann a.neumann at carto.net
Mon Feb 13 02:31:41 PST 2023
I am looking for a code snippet in PyQGIS: how can I change the filter
expression for a value relation widget?
Technically, the widget seems to be a QComboBox. I can get access to the
combobox, e.g. to get the current value - but how can I access the QGIS
related functionality, like changing programmatically settings of the
value relation widget , such as the filter expression? I found the
QgsValueRelationFieldFormatter object, but it doesn't allow me to change
the filter expression. Any idea how I would change the filter expression
using Python?
Thank you for any hints,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230213/82108c14/attachment.htm>
More information about the QGIS-Developer mailing list
