[QGIS-Developer] QgsGeometryUtils.lineCircleIntersection
Andrea Giudiceandrea andreaerdna at libero.it
Mon Feb 13 08:43:57 PST 2023
Hi Antonio,
Il 13/02/2023 15:46, Antonio Locandro via QGIS-Developer ha scritto:
> I am trying to use this on a script I am writing however I can’t seem
> to get what the syntax for the Qgs Vector should be, I was expecting
> just to put directly an angle but it is something else.
QgsVector(x: float, y: float)
See https://qgis.org/pyqgis/3.28/core/QgsVector.html#qgis.core.QgsVector
> On the other hand in order to use this function I need to write
> completely QgsGeometryUtils.lineCircleIntersection is there a way to
> make this shorter on my script?
lineCircleIntersection = QgsGeometryUtils.lineCircleIntersection
> Finally why some functions require QgsPointXY while others QgsPoint,
> beats me, just above this one is lineCircleIntersection that requires
> the use of PointXY
Probably because functions that use QgsPointXY only support 2D calculation.
Best regards.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230213/abd6f24a/attachment.htm>
More information about the QGIS-Developer mailing list
