[QGIS-Developer] Segmentation fault while compiling ui_DlgAddGeometryColumn.py
Denis Rouzaud denis.rouzaud at gmail.com
Thu Feb 16 10:50:46 PST 2023
Can you make clean and build again?
On Thu, 16 Feb 2023, 18:24 afernandez via QGIS-Developer, <
qgis-developer at lists.osgeo.org> wrote:
> Hello,
> My compilation is failing towards the end with a segmentation fault error,
> which I cannot figure out:
> [ 85%] Linking CXX shared module ../output/python/qgis/_gui.so
> [ 85%] Built target python_module_qgis__gui
> [ 85%] Built target pygui
> [ 85%] Generating ui_DlgAddGeometryColumn.py
> Segmentation fault (core dumped)
> make[2]: ***
> [python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/build.make:86:
> python/plugins/db_manager/ui_DlgAddGeometryColumn.py] Error 139
> make[2]: *** Deleting file
> 'python/plugins/db_manager/ui_DlgAddGeometryColumn.py'
> make[1]: *** [CMakeFiles/Makefile2:8465:
> python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/all]
> Error 2
> make: *** [Makefile:166: all] Error 2
> Not really sure how to troubleshoot this. OS is Ubuntu22.04 and
> architecture is aarch64.
> Thanks.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230216/b6b09404/attachment.htm>
More information about the QGIS-Developer mailing list
