[QGIS-Developer] createAlgorithmDialog in Processing script (within plugin)
matteo matteo.ghetta at gmail.com
Tue Feb 21 07:41:30 PST 2023
Hi devs,
I'm raising this email again because I don't know if this a
bug/limitation/correct behavior.
I also think that the problem is from a thread point of view, at least
by the crash that I have.
Knowing that a processing algorithm, as suggested by Germàn, can be
created with:
processing.createAlgorithmDialog("my_provider:my_algorithm", params)
within a plugin, if the algorithm **id** is passed as first argument,
QGIS is crashing, while it seems working on a standalone script in the
QGIS code editor.
Is this a limitation?
Cheers and thanks for any suggestion!
Matteo
On 8/1/22 15:23, matteo wrote:
> Hi all,
> I've a set of custom processing scripts within a plugin (that is both
> "normal" and processing provider plugin).
> I'm trying to executing the dialog of these algorithm from one of the
> main plugin file. I found the processing.createAlgorithmDialog [0], but
> it is constantly crashing when I'm passing the instance of the algorithm:
> my_alg = MyCustomAlg()
> my_dialog = my_alg.createAlgorithmDialog(custom_dict)
> ## crash here
> Thinking it was a problem of the threads I also tried to overwrite the
> `flag` method in the algorithm by setting also
> QgsProcessingAlgorithm.FlagNoThreading but with the same results.
> I know I can run the processing algorithm with processing.run(....) but
> I need to open the dialog pre-filled with custom parameters and to get
> also some other outputs besides the standard ones (like the
> QgsFeatureSink path)
> Thanks for any suggestion
> Cheers
> Matteo
> [0]
> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/tools/general.py#L155
More information about the QGIS-Developer mailing list
