[QGIS-Developer] PyQt db_manager(?) compile error
Richard Duivenvoorde rdmailings at duif.net
Fri Jan 27 04:23:31 PST 2023
Compiling master on Debian Testing today, I first was presented with a new dependency Qt5Multimedia (hopefully we can soon use QGIS as a Spotify client ;-) ), which was installable.
But then my (fresh) build stalls at:
[9773/9812] Generating ui_DlgAddGeometryColumn.py
FAILED: python/plugins/db_manager/ui_DlgAddGeometryColumn.py /home/richard/git/qgis/build/python/plugins/db_manager/ui_DlgAddGeometryColumn.py
cd /home/richard/git/qgis/build/python/plugins/db_manager && /home/richard/git/qgis/scripts/pyuic_wrapper.sh /usr/bin/pyuic5 /home/richard/git/qgis/build/output/lib /home/richard/git/qgis/build/output/python /usr/bin/python3 /home/richard/git/qgis/python/plugins/db_manager/ui/DlgAddGeometryColumn.ui -o /home/richard/git/qgis/build/python/plugins/db_manager/ui_DlgAddGeometryColumn.py
An unexpected error occurred.
Check that you are using the latest version of PyQt5 and send an error report to
support at riverbankcomputing.com, including the following information:
   * your version of PyQt (5.15.7)
   * the UI file that caused this error
   * the debug output of pyuic5 (use the -d flag when calling pyuic5)
Others have that issue?
Running pyuic -d on one of the errors seems fine (see below).
Regards,
/usr/bin/pyuic5 -d /home/richard/git/qgis/python/plugins/db_manager/ui/DlgExportVector.ui
PyQt5.uic.uiparser: uiname is DbManagerDlgExportVector
PyQt5.uic.uiparser: toplevel widget is QDialog
PyQt5.uic.properties: setting property geometry
PyQt5.uic.properties: setting property windowTitle
PyQt5.uic.uiparser: push QDialog DbManagerDlgExportVector
PyQt5.uic.uiparser: push QGridLayout gridLayout_2
PyQt5.uic.properties: setting property text
PyQt5.uic.uiparser: push QLineEdit editOutputFile
PyQt5.uic.uiparser: pop widget QLineEdit editOutputFile
PyQt5.uic.uiparser: new topwidget DbManagerDlgExportVector
PyQt5.uic.properties: setting property orientation
PyQt5.uic.properties: setting property standardButtons
PyQt5.uic.uiparser: push QDialogButtonBox buttonBox
PyQt5.uic.uiparser: pop widget QDialogButtonBox buttonBox
PyQt5.uic.uiparser: push QComboBox cboFileFormat
PyQt5.uic.uiparser: pop widget QComboBox cboFileFormat
PyQt5.uic.properties: setting property sizePolicy
PyQt5.uic.uiparser: push QLabel label_5
PyQt5.uic.uiparser: pop widget QLabel label_5
PyQt5.uic.properties: setting property title
PyQt5.uic.uiparser: push QGroupBox groupBox_2
PyQt5.uic.uiparser: push QCheckBox chkDropTable
PyQt5.uic.uiparser: pop widget QCheckBox chkDropTable
PyQt5.uic.uiparser: new topwidget self.groupBox_2
PyQt5.uic.uiparser: push QHBoxLayout horizontalLayout
PyQt5.uic.uiparser: push QCheckBox chkSourceSrid
PyQt5.uic.uiparser: pop widget QCheckBox chkSourceSrid
PyQt5.uic.properties: setting property enabled
PyQt5.uic.uiparser: push QLineEdit editSourceSrid
PyQt5.uic.uiparser: pop widget QLineEdit editSourceSrid
PyQt5.uic.uiparser: push QCheckBox chkTargetSrid
PyQt5.uic.uiparser: pop widget QCheckBox chkTargetSrid
PyQt5.uic.uiparser: push QLineEdit editTargetSrid
PyQt5.uic.uiparser: pop widget QLineEdit editTargetSrid
PyQt5.uic.uiparser: pop layout QHBoxLayout horizontalLayout
PyQt5.uic.properties: setting property toolTip
PyQt5.uic.uiparser: push QCheckBox chkEncoding
PyQt5.uic.uiparser: pop widget QCheckBox chkEncoding
PyQt5.uic.properties: setting property editable
PyQt5.uic.properties: setting property insertPolicy
PyQt5.uic.uiparser: push QComboBox cboEncoding
PyQt5.uic.uiparser: pop widget QComboBox cboEncoding
PyQt5.uic.uiparser: pop layout QGridLayout gridLayout
PyQt5.uic.uiparser: pop widget QGroupBox groupBox_2
PyQt5.uic.uiparser: push QToolButton btnChooseOutputFile
PyQt5.uic.uiparser: pop widget QToolButton btnChooseOutputFile
PyQt5.uic.uiparser: pop layout QGridLayout gridLayout_2
PyQt5.uic.uiparser: pop widget QDialog DbManagerDlgExportVector
PyQt5.uic.uiparser: new topwidget None
# -*- coding: utf-8 -*-
# Form implementation generated from reading ui file '/home/richard/git/qgis/python/plugins/db_manager/ui/DlgExportVector.ui'
# Created by: PyQt5 UI code generator 5.15.7
# WARNING: Any manual changes made to this file will be lost when pyuic5 is
# run again.  Do not edit this file unless you know what you are doing.
from PyQt5 import QtCore, QtGui, QtWidgets
class Ui_DbManagerDlgExportVector(object):
     def setupUi(self, DbManagerDlgExportVector):
         DbManagerDlgExportVector.setObjectName("DbManagerDlgExportVector")
         DbManagerDlgExportVector.resize(514, 253)
         self.gridLayout_2 = QtWidgets.QGridLayout(DbManagerDlgExportVector)
         self.gridLayout_2.setObjectName("gridLayout_2")
         self.editOutputFile = QtWidgets.QLineEdit(DbManagerDlgExportVector)
         self.editOutputFile.setText("")
         self.editOutputFile.setObjectName("editOutputFile")
         self.gridLayout_2.addWidget(self.editOutputFile, 1, 1, 1, 1)
         self.buttonBox = QtWidgets.QDialogButtonBox(DbManagerDlgExportVector)
         self.buttonBox.setOrientation(QtCore.Qt.Horizontal)
         self.buttonBox.setStandardButtons(QtWidgets.QDialogButtonBox.Cancel|QtWidgets.QDialogButtonBox.Ok)
         self.buttonBox.setObjectName("buttonBox")
         self.gridLayout_2.addWidget(self.buttonBox, 3, 0, 1, 3)
         self.cboFileFormat = QtWidgets.QComboBox(DbManagerDlgExportVector)
         self.cboFileFormat.setObjectName("cboFileFormat")
         self.gridLayout_2.addWidget(self.cboFileFormat, 0, 1, 1, 2)
         self.label_5 = QtWidgets.QLabel(DbManagerDlgExportVector)
         sizePolicy = QtWidgets.QSizePolicy(QtWidgets.QSizePolicy.Fixed, QtWidgets.QSizePolicy.Preferred)
         sizePolicy.setHorizontalStretch(0)
         sizePolicy.setVerticalStretch(0)
         sizePolicy.setHeightForWidth(self.label_5.sizePolicy().hasHeightForWidth())
         self.label_5.setSizePolicy(sizePolicy)
         self.label_5.setObjectName("label_5")
         self.gridLayout_2.addWidget(self.label_5, 1, 0, 1, 1)
         self.groupBox_2 = QtWidgets.QGroupBox(DbManagerDlgExportVector)
         self.groupBox_2.setObjectName("groupBox_2")
         self.gridLayout = QtWidgets.QGridLayout(self.groupBox_2)
         self.gridLayout.setObjectName("gridLayout")
         self.chkDropTable = QtWidgets.QCheckBox(self.groupBox_2)
         self.chkDropTable.setObjectName("chkDropTable")
         self.gridLayout.addWidget(self.chkDropTable, 2, 0, 1, 2)
         self.horizontalLayout = QtWidgets.QHBoxLayout()
         self.horizontalLayout.setObjectName("horizontalLayout")
         self.chkSourceSrid = QtWidgets.QCheckBox(self.groupBox_2)
         self.chkSourceSrid.setObjectName("chkSourceSrid")
         self.horizontalLayout.addWidget(self.chkSourceSrid)
         self.editSourceSrid = QtWidgets.QLineEdit(self.groupBox_2)
         self.editSourceSrid.setEnabled(False)
         self.editSourceSrid.setText("")
         self.editSourceSrid.setObjectName("editSourceSrid")
         self.horizontalLayout.addWidget(self.editSourceSrid)
         spacerItem = QtWidgets.QSpacerItem(40, 20, QtWidgets.QSizePolicy.Fixed, QtWidgets.QSizePolicy.Minimum)
         self.horizontalLayout.addItem(spacerItem)
         self.chkTargetSrid = QtWidgets.QCheckBox(self.groupBox_2)
         self.chkTargetSrid.setObjectName("chkTargetSrid")
         self.horizontalLayout.addWidget(self.chkTargetSrid)
         self.editTargetSrid = QtWidgets.QLineEdit(self.groupBox_2)
         self.editTargetSrid.setEnabled(False)
         self.editTargetSrid.setText("")
         self.editTargetSrid.setObjectName("editTargetSrid")
         self.horizontalLayout.addWidget(self.editTargetSrid)
         self.gridLayout.addLayout(self.horizontalLayout, 0, 0, 1, 2)
         self.chkEncoding = QtWidgets.QCheckBox(self.groupBox_2)
         self.chkEncoding.setObjectName("chkEncoding")
         self.gridLayout.addWidget(self.chkEncoding, 1, 0, 1, 1)
         self.cboEncoding = QtWidgets.QComboBox(self.groupBox_2)
         self.cboEncoding.setEnabled(False)
         sizePolicy = QtWidgets.QSizePolicy(QtWidgets.QSizePolicy.Expanding, QtWidgets.QSizePolicy.Fixed)
         sizePolicy.setHeightForWidth(self.cboEncoding.sizePolicy().hasHeightForWidth())
         self.cboEncoding.setSizePolicy(sizePolicy)
         self.cboEncoding.setEditable(False)
         self.cboEncoding.setInsertPolicy(QtWidgets.QComboBox.NoInsert)
         self.cboEncoding.setObjectName("cboEncoding")
         self.gridLayout.addWidget(self.cboEncoding, 1, 1, 1, 1)
         self.gridLayout_2.addWidget(self.groupBox_2, 2, 0, 1, 3)
         self.btnChooseOutputFile = QtWidgets.QToolButton(DbManagerDlgExportVector)
         self.btnChooseOutputFile.setObjectName("btnChooseOutputFile")
         self.gridLayout_2.addWidget(self.btnChooseOutputFile, 1, 2, 1, 1)
         self.label = QtWidgets.QLabel(DbManagerDlgExportVector)
         self.label.setObjectName("label")
         self.gridLayout_2.addWidget(self.label, 0, 0, 1, 1)
         self.retranslateUi(DbManagerDlgExportVector)
         self.buttonBox.rejected.connect(DbManagerDlgExportVector.reject) # type: ignore
         self.chkSourceSrid.toggled['bool'].connect(self.editSourceSrid.setEnabled) # type: ignore
         self.chkTargetSrid.toggled['bool'].connect(self.editTargetSrid.setEnabled) # type: ignore
         self.chkEncoding.toggled['bool'].connect(self.cboEncoding.setEnabled) # type: ignore
         self.buttonBox.accepted.connect(DbManagerDlgExportVector.accept) # type: ignore
         QtCore.QMetaObject.connectSlotsByName(DbManagerDlgExportVector)
         DbManagerDlgExportVector.setTabOrder(self.chkSourceSrid, self.editSourceSrid)
         DbManagerDlgExportVector.setTabOrder(self.editSourceSrid, self.chkEncoding)
         DbManagerDlgExportVector.setTabOrder(self.chkEncoding, self.cboEncoding)
         DbManagerDlgExportVector.setTabOrder(self.cboEncoding, self.buttonBox)
     def retranslateUi(self, DbManagerDlgExportVector):
         _translate = QtCore.QCoreApplication.translate
         DbManagerDlgExportVector.setWindowTitle(_translate("DbManagerDlgExportVector", "Export to vector file"))
         self.label_5.setText(_translate("DbManagerDlgExportVector", "Save as"))
         self.groupBox_2.setTitle(_translate("DbManagerDlgExportVector", "Options"))
         self.chkDropTable.setText(_translate("DbManagerDlgExportVector", "Replace destination file (if exists)"))
         self.chkSourceSrid.setText(_translate("DbManagerDlgExportVector", "Source SRID"))
         self.chkTargetSrid.setText(_translate("DbManagerDlgExportVector", "Target SRID"))
         self.chkEncoding.setToolTip(_translate("DbManagerDlgExportVector", "Output file encoding"))
         self.chkEncoding.setText(_translate("DbManagerDlgExportVector", "Encoding"))
         self.btnChooseOutputFile.setText(_translate("DbManagerDlgExportVector", "…"))
         self.label.setText(_translate("DbManagerDlgExportVector", "Format"))
More information about the QGIS-Developer mailing list
