[QGIS-Developer] Call of testing of nightlies on hi-dpi displays
Stephen Knox stephenknox73 at gmail.com
Thu Jun 1 00:44:37 PDT 2023
On 5/29/23 06:01, Nyall Dawson via QGIS-Developer wrote:
> Hi lists,
> For the upcoming QGIS 3.32 release a change has been made in how QGIS
> handles high dpi (and retina) displays. This should ultimately make
> QGIS behave MUCH better on these displays, but there's likely some
> short-term fallout and regressions caused by the change.
Thank you for this Nyall.
It certainly makes a big difference on my display: https://imgur.com/a/lAmBaUw
Haven't found any areas where icons continue to be abnormally large
yet, apart from those identified, but will keep an eye out.
Stephen
On Tue, May 30, 2023 at 12:11 AM Nyall Dawson via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> On Mon, 29 May 2023 at 19:23, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> > Hi Nyall,
> > Happy to do some testing, I do have a (dual boot) laptop/tablet with 3000x2000 screen (that's high-dpi, yes?), but in Gnome I set the Display 'Scale' on 200% to have proper applications (an to me readable text :-) ).
> > Is there some test plan/idea's?
> There's a few things in particular we need to identify:
> - Widgets which are now showing as pixelated. Basically just hunt
> through the UI looking for things which look pixelated! This might be
> icons, graphics, or even just the drawing of the widget itself. You'll
> spot them immediately, as they clearly stand out. But there's a LOT of
> different dialogs/tabs/widgets/pages/... in QGIS and it will take some
> time to hunt through them all.
> - Icons/images which look the wrong size. Eg the marker symbols shown
> in the layer tree right now are incorrectly sized and will be half the
> size of the actual symbol shown on the map. That's a known regression,
> but there's likely others like this hiding around the place.
> - Text which is the wrong size. If something has a hard-coded sizing
> it's possible that we'll get fonts scaled badly, so if you spot any
> text which noticably looks incorrectly sized vs other UI elements then
> that's also something we need to fix.
> > Is my setup something you want to test (200%), or is is preferred to use the 100% scale?
> This is EXACTLY the kind of setup we need testing on! If the display
> scaling is set to 100% (in Windows, or Linux), then you'll see no
> difference between the old approach vs new. The new logic only kicks
> in when display scaling is present.
> > I'm not sure what is supposed to be the 'normal' way of scaling (like what does a mac do)?
> Things should just look perfect, regardless of whether or not display
> scaling is active :)
> Nyall
> > Or is it more to try to see if the icons/widgets scale up/down when fidling with scale (or what it is called in Windows)?
> > Regards,
> > > Hi lists,
> > > If you've access to a high-dpi display, please test out the nightly
> > > releases and file bug reports on github for any regressions you spot
> > > -- in particular we are looking for widgets and places where the QGIS
> > > interface is now looking pixelated or where the scale / sizes of
> > > objects are incorrect.
> > > (Currently there's known regressions for the icons shown in the layer
> > > tree panel, and for pixelated icons in the style manager dialog.)
> > > Thanks in advance!
> > > Nyall
> > > _______________________________________________
> > > QGIS-Developer mailing list
> > > QGIS-Developer at lists.osgeo.org
> > > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
