[QGIS-Developer] Why so many database calls?
Cory Albrecht maps at hanfastolfe.com
Thu Jun 15 14:40:17 PDT 2023
Hello,
So I've been trying to track down why my postgresql server was getting so
many Signal 10 (SUG BS, memory bus) errors. So far I have figured out that
they are only happening when QGIS is connecting to it using GSS/Kerberos
encryption. No clue yet as to which side is the culprit (e.g. bad QGIS
kerberised data flow, or bad PostgreSQL handling of the connection). QGIS
cinnectio with SSL encryption is fine.
Anyways, while doing this I've been watching a lot of PostgreSQL server
logs, and I noticed the following behaviour of QGIS:
When using the vertex editor to delete a whole slew (1,000-ish) vertices
from a polygon feature, I saw that QGIS was making repeated DB cals like
this:
Jun 15 17:14:19 postgresql-3 postgres[87136]: [3204-1] ::>[2023-06-15
17:14:19.289 EDT][648b7d94.15460][87136/] <maps%Alternate History> LOG:
 duration: 0.330 ms  statement: BEGIN READ ONLY;DECLARE qgis_1062 BINARY
CURSOR FOR SELECT
"feature_uuid"::text,"name"::text,"start_date"::text,"end_date"::text,"main_rgb"::text,"realm_uuid"::text,"stripe_rgb"::text,"border_rgb"::text,"border_shade"::text,"sovereign"::text,"type"::text,"info_url"::text,array_out("predecessors")::text,array_out("successors")::text,boolout("visible")::text,boolout("has_children")::text,"full_name"::text,"alternate_name"::text,"flag_url"::text
FROM "Balance of Power"."timeline_level0" WHERE
"feature_uuid"::text='fbbec581-eb8f-4068-8729-8f9d63896bd5'
Jun 15 17:14:19 postgresql-3 postgres[87136]: [3205-1] ::>[2023-06-15
17:14:19.290 EDT][648b7d94.15460][87136/] <maps%Alternate History> LOG:
 duration: 0.628 ms  statement: FETCH FORWARD 2000 FROM qgis_1062
Jun 15 17:14:19 postgresql-3 postgres[87136]: [3206-1] ::>[2023-06-15
17:14:19.291 EDT][648b7d94.15460][87136/] <maps%Alternate History> LOG:
 duration: 0.045 ms  statement: CLOSE qgis_1062;COMMIT
An example of the QGIS console output:
./src/core/qgsmessagelog.cpp:29 : (logMessage) [4ms] 2023-06-15T17:37:08
PostGIS[1] NOTICE: LOG:  duration: 0.399 ms  statement: FETCH FORWARD 2000
FROM qgis_2017
./src/core/qgsmessagelog.cpp:29 : (logMessage) [1ms] 2023-06-15T17:37:08
PostGIS[1] NOTICE: LOG:  duration: 0.035 ms  statement: CLOSE
qgis_2017;COMMIT
./src/core/qgsmessagelog.cpp:29 : (logMessage) [3ms] 2023-06-15T17:37:08
PostGIS[1] NOTICE: LOG:  duration: 0.240 ms  statement: BEGIN READ
ONLY;DECLARE qgis_2018 BINARY CURSOR FOR SELECT
./src/core/qgsmessagelog.cpp:29 : (logMessage) [2ms] 2023-06-15T17:37:08
PostGIS[1] NOTICE: LOG:  duration: 0.406 ms  statement: FETCH FORWARD 2000
FROM qgis_2018
PostGIS[1] NOTICE: LOG:  duration: 0.034 ms  statement: CLOSE
qgis_2018;COMMIT
That is repeated 4 times every couple of seconds as I wait for QGIS to
finish deleting these 1,000-ish vertices. So far it's at begin block
qgis_2058 (increasing sequentially) and it's been 20+ minutes that QGIS has
been frozen, CPU usage for the process jumping around between 100% and 300%.
(Before you ask, Fall 2021 Dell XPS 9510, 11th Gen Intel Core i9-11900H @
2.50GHz 8 cores, 64GB RAM.)
So why is it repeatedly making database calls to get the non geometry
attributes of that same singular feature? Why can't it just use the cached
data instead of making all these wasteful DB queries?
And why is it taking so long to delete the vertices? Is it related to all
the unnecessary DB queries?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230615/7aac644d/attachment.htm>
More information about the QGIS-Developer mailing list
