[QGIS-Developer] QGIS builds source for qtwebkit?
Alexandre Neto senhor.neto at gmail.com
Fri Jun 16 06:39:26 PDT 2023
Are we (actually Jürgen) building qtwebkit from source? what is the source that is being used. At conda-forge we were using the link below, which was removed from qt.io <http://qt.io> site.
http://download.qt.io/snapshots/ci/qtwebkit/5.212/1600955993/src/submodules/qtwebkit-opensource-src-5.212.tar.xz <http://download.qt.io/snapshots/ci/qtwebkit/5.212/1600955993/src/submodules/qtwebkit-opensource-src-5.212.tar.xz>
We found this:
https://github.com/movableink/webkit/releases <https://github.com/movableink/webkit/releases>
But I wanted to confirm if the official builds use the source from other place.
thanks!
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230616/cdb9240b/attachment.htm>
More information about the QGIS-Developer mailing list
