[QGIS-Developer] qgis ubuntu 20.04 dependencies
Even Rouault
even.rouault at spatialys.com
Mon Jun 19 11:48:22 PDT 2023
Le 19/06/2023 à 20:44, Hugh Kelley a écrit :
> OK thanks, exactly the general guidance I was looking for. I'll look
> into upgrading. Is there currently a version that makes things easiest?
QGIS continuous integration uses:
- ubuntu 22.04 for QT5 builds:
https://github.com/qgis/QGIS/blob/master/.docker/qgis3-qt5-build-deps.dockerfile
- Fedora 38 for QG6 builds:
https://github.com/qgis/QGIS/blob/master/.docker/qgis3-qt6-build-deps.dockerfile
> On Mon, Jun 19, 2023 at 2:34 PM Even Rouault
> <even.rouault at spatialys.com> wrote:
> Building recent QGIS versions on 20.04 is going to be quite a lot
> of pain since you'll need indeed to have a qt 5.15 build, and all
> the other auxiliary QT based dependencies build against it.
> I'd suggest you update to 22.04 at least. Or if you don't want to
> do development but can live with released versions, try
> conda-forge builds (cf https://plugins.qgis.org/planet/tag/conda/)
> Le 19/06/2023 à 20:30, Hugh Kelley via QGIS-Developer a écrit :
>> Hi all,
>> while working on compiling qgis on ubuntu using these
>> instructions [0] , i've run into an error while running cmake
>> that "QRecursiveMutex" is not found.
>> It looks like that became available in QT 5.14.
>> Ubuntu 20.04 installs QT 5.12. During my searches i've seen
>> comments that imply 5.15 might not be available for 20.04. I'm
>> trying to figure out whether I should be trying to upgrade Qt, if
>> I have to upgrade Ubuntu, or if there is some option in the
>> compilation process that can resolve this for me.
>> I've installed Qt 5.15.2 to /opt/ and added it to PATH, but
>> qtdiag still indicates i'm using 5.12.x
>> I thought i'd start by asking here before asking on a Qt general
>> forum in case there's a qgis specific solution.
>> I've also set the cmake 3d option to "no" which got me around the
>> absence of q qt 3d extras pacakge/file. So maybe there's a
>> similar solution for this although this version problem seem more
>> essential.
>> Thanks for any suggestions!
>> [0] https://github.com/qgis/QGIS/blob/master/INSTALL.md
>> Hugh Kelley
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> http://www.spatialys.com
> My software is free, but my time generally not.
> Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230619/7b69d9a6/attachment.htm>
