[QGIS-Developer] GeoFerver canno't read QGIS server WFS Services
Walter Lorenzetti
lorenzetti at gis3w.it
Tue Jun 20 05:00:56 PDT 2023
Hi René-Luc any idea about it?
W
Il 05/06/23 15:48, Walter Lorenzetti via QGIS-Developer ha scritto:
> René-Luc there it is:
> <schema targetNamespace="http://www.qgis.org/gml"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:gml="http://www.opengis.net/gml" version="1.0"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xmlns="http://www.w3.org/2001/XMLSchema"
> elementFormDefault="qualified"
> xmlns:qgs="http://www.qgis.org/gml">
> <import
> schemaLocation="http://schemas.opengis.net/gml/3.1.1/base/gml.xsd"
> namespace="http://www.opengis.net/gml"/>
> <element name="Particelle_terreni_e_fabbricati"
> substitutionGroup="gml:_Feature"
> type="qgs:Particelle_terreni_e_fabbricatiType"/>
> <complexType name="Particelle_terreni_e_fabbricatiType">
> <complexContent>
> <extension base="gml:AbstractFeatureType">
> <sequence>
> <element name="geometry"
> type="gml:PolygonPropertyType" maxOccurs="1" minOccurs="0"/>
> <element name="gid" type="int"/>
> <element name="tipo" type="string" nillable="true"/>
> <element name="foglio" type="int" nillable="true"/>
> <element name="numero" type="string" nillable="true"/>
> <element name="sezione" type="string"
> nillable="true"/>
> <element name="allegato" type="string"
> nillable="true"/>
> <element name="codice_comune" type="string"/>
> <element name="nomefile" type="string"
> nillable="true"/>
> <element name="task_id" type="string"
> nillable="true"/>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> </schema>
> Il 05/06/23 09:59, René-Luc Dhont ha scritto:
>> Hi Walter,
>> The issue concerns Particelle_terreni_e_fabbricati layer.
>> Can you check the DescribeFeatureType for this layer:
>> Particelle_terreni_e_fabbricati ?
>> Regards,
>> René-Luc
>> Le 05/06/2023 à 09:26, Walter Lorenzetti a écrit :
>>> Hi René-Luc,
>>> yes it fail on DescribeFeatureType.
>>> This is the repsonse of QGIS 3.28.7:
>>> <schema xmlns:gml="http://www.opengis.net/gml"
>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="1.0"
>>> xmlns:ogc="http://www.opengis.net/ogc" elementFormDefault="qualified">
>>> <import
>>> <element name="buildings" substitutionGroup="gml:_Feature"
>>> type="qgs:buildingsType"/>
>>> <complexType name="buildingsType">
>>> <complexContent>
>>> <sequence>
>>> <element maxOccurs="1" name="geometry" minOccurs="0"
>>> type="gml:MultiSurfacePropertyType"/>
>>> <element name="fid" alias="ID" type="long"/>
>>> <element name="name" alias="Name" type="string"/>
>>> <element name="address" alias="Address" type="string"
>>> nillable="true"/>
>>> <element name="year" alias="Year of construction" type="long"/>
>>> <element name="photo" alias="Photo" type="string" nillable="true"/>
>>> <element name="link" alias="Link" type="string" nillable="true"/>
>>> <element name="form" alias="Form" type="string" nillable="true"/>
>>> <element name="high" alias="High" type="long"/>
>>> <element name="volume" alias="Volume" type="long" nillable="true"/>
>>> <element name="surface" alias="Surface (based on QGIS
>>> expression)" type="decimal" nillable="true"/>
>>> <element name="architectural_barriers" alias="Architectural
>>> barriers" type="string" nillable="true"/>
>>> <element name="date_barriers" alias="Date" type="date"
>>> nillable="true"/>
>>> <element name="safety_exits" alias="Safety exits" type="string"
>>> nillable="true"/>
>>> <element name="date_exits" alias="Date" type="date"
>>> nillable="true"/>
>>> <element name="fire_system" alias="Fire system" type="string"
>>> nillable="true"/>
>>> <element name="date_fire" alias="Date" type="date"
>>> nillable="true"/>
>>> <element name="type" alias="Type" type="string"/>
>>> <element name="zone" alias="Zone (based on QGIS expression)"
>>> <element name="attachment" alias="Documents to be attached"
>>> <element name="subtype" alias="Subtype - Dependent on the value
>>> of Type" type="string" nillable="true"/>
>>> <element name="user" alias="User last modification"
>>> <element name="description" alias="Description" type="string"
>>> nillable="true"/>
>>> </sequence>
>>> </extension>
>>> </complexContent>
>>> </complexType>
>>> </schema>
>>> and following a DescribeFeatureType response which does not fail on
>>> geoservers from a Italy government service:
>>> http://wms.pcn.minambiente.it/ogc?map=/ms_ogc/wfs/Alluvioni_Estensione.map&TYPENAME=ITH2018_Estensione_LPH&REQUEST=DescribeFeatureType&VERSION=1.1.0&SERVICE=WFS
>>> <?xml version='1.0' encoding="ISO-8859-1" ?>
>>> <schema
>>> targetNamespace="http://mapserver.gis.umn.edu/mapserver"
>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>> elementFormDefault="qualified" version="0.1" >
>>> <import namespace="http://www.opengis.net/gml"
>>> schemaLocation="http://schemas.opengis.net/gml/3.1.1/base/gml.xsd" />
>>> <element name="ITH2018_Estensione_LPH"
>>> type="ms:ITH2018_Estensione_LPHType"
>>> substitutionGroup="gml:_Feature" />
>>> <complexType name="ITH2018_Estensione_LPHType">
>>> <complexContent>
>>> <sequence>
>>> <element name="boundary" type="gml:SurfacePropertyType"
>>> minOccurs="0" maxOccurs="unbounded"/>
>>> <element name="id" type="string"/>
>>> <element name="rbdname" type="string"/>
>>> <element name="uomcode" type="string"/>
>>> <element name="apsfrcode" type="string"/>
>>> <element name="category" type="string"/>
>>> <element name="eu_cd_hp" type="string"/>
>>> <element name="source" type="string"/>
>>> <element name="character" type="string"/>
>>> <element name="mechanism" type="string"/>
>>> <element name="frequency" type="string"/>
>>> <element name="namespace" type="string"/>
>>> <element name="beginlife" type="string"/>
>>> <element name="detmetod" type="string"/>
>>> </sequence>
>>> </extension>
>>> </complexContent>
>>> </complexType>
>>> </schema>
>>> I can't see a substantial difference :(
>>> W
>>> Il 31/05/23 15:28, René-Luc Dhont via QGIS-Developer ha scritto:
>>>> Hi Walter,
>>>> You have to check the result of DescribeFeatureType WFS Request.
>>>> This request has to provide the XSD to validate the GML.
>>>> Regards,
>>>> René-Luc
>>>> Le 31/05/2023 à 14:59, Walter Lorenzetti via QGIS-Developer a écrit :
>>>>> Hi,
>>>>> when I try to add a WFS service layer to a GeoServer instance I
>>>>> get an exception like this:
>>>>> Caused by: java.lang.RuntimeException:
>>>>> org.geotools.data.DataSourceException: No XSDElementDeclaration
>>>>> found for {http://www.opengis.net/wfs}Particelle_terreni_e_fabbricati
>>>>> at
>>>>> org.geotools.data.store.ContentFeatureSource.getAbsoluteSchema(ContentFeatureSource.java:329)
>>>>> at
>>>>> org.geotools.data.store.ContentFeatureSource.getSchema(ContentFeatureSource.java:296)
>>>>> at
>>>>> org.geotools.data.store.ContentFeatureSource.getSchema(ContentFeatureSource.java:105)
>>>>> at
>>>>> org.geoserver.catalog.CatalogBuilder.buildFeatureType(CatalogBuilder.java:342)
>>>>> at
>>>>> org.geoserver.catalog.CatalogBuilder.buildFeatureType(CatalogBuilder.java:325)
>>>>> at
>>>>> org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:409)
>>>>> Any idea about this issue? It seams a XML error validation..
>>>>> Thanks in advance.
>>>>> W
>>>>> Walter Lorenzetti phD
>>>>> email: lorenzetti at gis3w.it
>>>>> site: gis3w.it <https://gis3w.it>
>>>>> twitter: w_lorenzetti
>>>>> Tel/Cell: (+39) 347-6597931
>>>>> Viale Verdi 24 - 51016 Montecatini Terme (PT)
>>>>> _______________________________________________
>>>>> QGIS-Developer mailing list
>>>>> QGIS-Developer at lists.osgeo.org
>>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230620/80ef594e/attachment-0001.htm>
