[QGIS-Developer] inf and nan in reclassify algo
Sebastian Gutwein bas at rdgland.com
Thu Nov 23 09:22:27 PST 2023
I recently discovered by trying likely things that I can use inf, -inf, and
nan in the reclassify algo.
Not being a programmer it wasn't obvious that these would be valid inputs.
I would like to document this.
https://github.com/qgis/QGIS-Documentation/pull/8653
>From my research it seems like these are inherent special values in the
floating point format in C++.
https://en.cppreference.com/w/cpp/language/types
The inf and -inf seem straightforward to use in the reclassify table as max
and min values and nan seems to work to set a range of values to nodata.
Are there any gotchas I'm missing or any other values that can be used and
should be documented?
Thanks
-Bas
___________________________
Sebastian "Bas* " Gutwein
*rhymes with Josh
Regenerative Design Group
1 Chevalier Ave
Greenfield, Ma 01301
Web: regenerativedesigngroup.com
(631) 241-1018
*Look close, think big, make change. *
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231123/94daff75/attachment.htm>
More information about the QGIS-Developer mailing list
