[QGIS-Developer] QGIS Full Stack Web Developer Report
Matthias Kuhn matthias at opengis.ch
Mon Nov 27 01:24:04 PST 2023
Hi Tim,
For the workflow, that sounds great, thanks a lot!
I agree only breaking changes should go "the long way" and for simple fixes
and improvements we should just get them done with low overhead.
Going forward with a small QEP for the license sounds very good.
Regarding the metadata, I would suggest we use the ids from
https://spdx.org/licenses/.
So for the usual QGIS plugin case, that would be
    license=GPL-2.0-or-later
On another note, I just added a couple of tickets to the backlog, I am not
able to estimate the size of them, so if they are too complicated, just
don't prioritize them.
Thank you and best regards
Matthias
On Mon, Nov 27, 2023 at 10:15 AM Tim Sutton <tim at kartoza.com> wrote:
> Hi all
> On Mon, Nov 27, 2023 at 1:32 AM Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
>> On Mon, 27 Nov 2023 at 00:19, Tim Sutton via QGIS-Developer <
>> qgis-developer at lists.osgeo.org> wrote:
>> > @Matthias Kuhn and @Julien Moura I fixed the permissions, the board for
>> Lova is public now. Please feel free to add items to the backlog and mark
>> them as priority as needed.  I also asked Lova to try to work through all
>> the old issues and fix / close them as appropriate so we can try to get the
>> number of tickets down to a small number.
>> Tim/Lova, thanks for your outstanding efforts and commitment here!
>> It's really exciting to see all the love and attention that the web and
>> plugin infrastructure is getting as a result! 😍
> Thanks so much Nyall and all credit goes to Lova who is doing fantastic
> work! What I suggest is that moving forward, Lova uses QEP's too propose
> and discuss breaking / major workflow changes on the plugins site. In that
> QEP he can address:
> * what the change is (link back to ticket in QGIS-Django for example)
> * what the impact will be
> * proposed roll out time line
> etc.
> And we can discuss and agree these changes there before he goes ahead with
> it. For smaller changes, I suggest he 'just get on with it' - his scrum
> board is public and you are all welcome to help prioritise his work.
> For the current issue under discussion (license requirements for plugins),
> I have asked Lova to make a QEP and synthesize the discussion there, mainly
> so he can have a practice run at going through the QEP process, although I
> will add my 2c that I like Matthias' simple solution to the problem (adding
> license as a line to the metadata.txt). If I understand you right Matthias,
> our metadata would then look like this?:
> [general]
> name=QGIS Animation Workbench
> description=A plugin to let you build animations in QGIS
> about=QGIS Animation Bench exists because we wanted to use all the awesome
> cartography features in QGIS and make cool, animated maps! QGIS already
> includes the Temporal Manager which allows you to produce animations for
> time-based data. But what if you want to make animations where you travel
> around the map, zooming in and out, and perhaps making features on the map
> wiggle and jiggle as the animation progresses? That is what the animation
> workbench tries to solve...
> version=1.1
> qgisMinimumVersion=3.0
> author=Tim Sutton
> email=tim at kartoza.com
> repository=https://github.com/timlinux/QGISAnimationPlugin
> license=GPLv2
> There is probably another thread to this discussion which is to understand
> which license are accepted and which not, but that is a job for another QEP
> I guess...!
> Regards
> Tim
>> Nyall
> 8< ----------- snip -----------------
> Tim Sutton
> Kartoza Co-Founder
> Visit http://kartoza.com to find out about open source:
>  * Desktop GIS programming services
>  * Geospatial web development
> * GIS Training
> * Consulting Services
> Tim is a member of the QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231127/cb2d8d7f/attachment-0001.htm>
More information about the QGIS-Developer mailing list
