[QGIS-Developer] QGIS Full Stack Web Developer Report
Julien Moura julien.moura at oslandia.com
Mon Nov 27 03:41:09 PST 2023
Hello,
Thanks again for the technical work and improving the workflow.
+1 for the lazy consensus on non breaking changes.
Regarding the license topic:
+1 for the metadata field with a spdx license. But take care, it's not
so easy to a have an exhaustive list. Maybe we should move to the PyPi
classifiers since plugins are Python packages and there is already a
work on maintaining a metadata ecosystem, including tooling to check it
(pip install packaging).
Are we okay with the step back to only a non-blocking warning?
Regards
On 27/11/2023 10:50, Lova Andriarimalala via QGIS-Developer wrote:
> Hello everyone,
> Thank you all. It's truly an honorto work on this project.
> I will begin by utilizing QEP to create a QEP that summarizes this
> discussion and going forward with the suggestion to make the license
> file recommended for now.
> I have reviewed the tickets in the backlog and will evaluate their
> size. If I come across anything that I don't understand, I will add
> comments to seek clarification.
> Best regards,
> Lova
> Image
> *Lova Andriarimalala***
> *QGIS Full Stack Developer***
> Visit http://kartoza.com <http://kartoza.com/> to find out about open
> source:
> * Desktop GIS programming services
> * Geospatial web development
> * GIS Training
> * Consulting Services
> Office: +261(0)34 09 524 73 <tel:+261340952473>
> *From: *QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> on
> behalf of Matthias Kuhn via QGIS-Developer
> <qgis-developer at lists.osgeo.org>
> *Date: *Monday, 27 November 2023 at 12:24 PM
> *To: *Tim Sutton <tim at kartoza.com>
> *Cc: *qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>
> *Subject: *Re: [QGIS-Developer] QGIS Full Stack Web Developer Report
> Hi Tim,
> For the workflow, that sounds great, thanks a lot!
> I agree only breaking changes should go "the long way" and for simple
> fixes and improvements we should just get them done with low overhead.
> Going forward with a small QEP for the license sounds very good.
> Regarding the metadata, I would suggest we use the ids from
> https://spdx.org/licenses/.
> So for the usual QGIS plugin case, that would be
>   license=GPL-2.0-or-later
> On another note, I just added a couple of tickets to the backlog, I am
> not able to estimate the size of them, so if they are too complicated,
> just don't prioritize them.
> Thank you and best regards
> Matthias
> On Mon, Nov 27, 2023 at 10:15 AM Tim Sutton <tim at kartoza.com> wrote:
>     Hi all
>     On Mon, Nov 27, 2023 at 1:32 AM Nyall Dawson
>     <nyall.dawson at gmail.com> wrote:
>         On Mon, 27 Nov 2023 at 00:19, Tim Sutton via QGIS-Developer
>         <qgis-developer at lists.osgeo.org> wrote:
>         > @Matthias Kuhn and @Julien Moura I fixed the permissions,
>         the board for Lova is public now. Please feel free to add
>         items to the backlog and mark them as priority as needed.  I
>         also asked Lova to try to work through all the old issues and
>         fix / close them as appropriate so we can try to get the
>         number of tickets down to a small number.
>         Tim/Lova, thanks for your outstanding efforts and
>         commitment here!
>         It's really exciting to see all the love and attention that
>         the web and plugin infrastructure is getting as a result! 😍
>     Thanks so much Nyall and all credit goes to Lova who is doing
>     fantastic work! What I suggest is that moving forward, Lova uses
>     QEP's too propose and discuss breaking / major workflow changes on
>     the plugins site. In that QEP he can address:
>     * what the change is (link back to ticket in QGIS-Django for example)
>     * what the impact will be
>     * proposed roll out time line
>     etc.
>     And we can discuss and agree these changes there before he goes
>     ahead with it. For smaller changes, I suggest he 'just get on with
>     it' - his scrum board is public and you are all welcome to help
>     prioritise his work.
>     For the current issue under discussion (license requirements for
>     plugins), I have asked Lova to make a QEP and synthesize the
>     discussion there, mainly so he can have a practice run at going
>     through the QEP process, although I will add my 2c that I like
>     Matthias' simple solution to the problem (adding license as a line
>     to the metadata.txt). If I understand you right Matthias, our
>     metadata would then look like this?:
>     [general]
>     name=QGIS Animation Workbench
>     description=A plugin to let you build animations in QGIS
>     about=QGIS Animation Bench exists because we wanted to use all the
>     awesome cartography features in QGIS and make cool, animated maps!
>     QGIS already includes the Temporal Manager which allows you to
>     produce animations for time-based data. But what if you want to
>     make animations where you travel around the map, zooming in and
>     out, and perhaps making features on the map wiggle and jiggle as
>     the animation progresses? That is what the animation workbench
>     tries to solve...
>     version=1.1
>     qgisMinimumVersion=3.0
>     author=Tim Sutton
>     email=tim at kartoza.com
>     repository=https://github.com/timlinux/QGISAnimationPlugin
>     license=GPLv2
>     There is probably another thread to this discussion which is to
>     understand which license are accepted and which not, but that is a
>     job for another QEP I guess...!
>     Regards
>     Tim
>         Nyall
>     8< ----------- snip -----------------
>     Tim Sutton
>     Kartoza Co-Founder
>     Visit http://kartoza.com to find out about open source:
>     * GIS Training
>     Tim is a member of the QGIS Project Steering Committee
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231127/d05d9226/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231127/d05d9226/attachment-0001.jpg>
Type: text/vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231127/d05d9226/attachment-0001.vcf>
More information about the QGIS-Developer mailing list
