[QGIS-Developer] QGIS repository management
    Matthias Kuhn
    matthias at opengis.ch
    Tue Oct 17 23:24:51 PDT 2023
On Tue, Oct 17, 2023 at 9:19 PM Nyall Dawson via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> > IMHO, the main issue here is that the CI is too often broken for no
> > reasons related to the PR content. And most of the time recently, it's
> > because of one of the mingw jobs.
> I suggest we move this conversation into more practical areas and
> focus instead on the actual CI issues.
> In my experience there's a couple of main issues here:
> 1. The mingw build fails often with the error:
> cd /__w/QGIS/QGIS/build_mingw64/resources && /usr/bin/cmake -E copy
> /__w/QGIS/QGIS/resources/srs6.db
> /__w/QGIS/QGIS/build_mingw64/resources/srs.db
> make[2]: write error: stdout
> It always succeeds if you restart the job though. I don't know what's
> causing this... a disk space issue? (but then why would it succeed on
> the following attempt?)
mingw runs on ubuntu-latest within a fedora container. ubuntu images come
with plenty of bloat preinstalled that can be easily deleted.
cf.
https://github.com/easimon/maximize-build-space/blob/master/action.yml#L114-L130
I just don't know how to do that if a "container" is specified as the
delete action will need to happen on the base system.
> 2. The msys2 build can take HOURS (5+ in some cases). The qt 5/ qt6
> builds also see occasional extremely slow builds.
> I think the root cause of this is that we've exhausted all the
> available space allowed for caching objects on github. All the builds
> are trying to cache things to speed up the workflows, but the
> different caches are randomly getting deleted because together they've
> well exceeded the total allowed size. The solutions I could see here
> are:
> - approaching github to ask nicely for more space
> - dropping one or more workflows. Maybe we could combine the msys2 and
> mingw workflow into one to cut out one workflow. But that's blocked
> because the msys2 workflow currently has a lot of things disabled
> (including python), so it's currently not a suitable replacement for
> the mingw builds which give end users an easy way to test PRs on
> windows.
What is the advantage of the msys2 workflow?
It does "some build on windows" but IIUC does not replicate the actual
windows build using OSGEO4W. Is there something else that it brings to the
mix?
> 3. Random test failures. Main culprits are:
> - ept provider test (but I **think** I've fixed this with
> improvements/fixes made over the 3.34 bug fixing period). At least, I
> don't recall seeing this in the last week, when it used to be a daily
> random fail.
> - raster file writer test: randomly fails for an unknown reason. The
> test passes valgrind/asan fine, so I suspect the random failures are
> caused by some interplay with other tests modifying data in the test
> data folder. More work is needed.
> - raster analysis utils test: same as above.
> - network access manager test: depends on the badssl external website,
> which goes down occasionally. We could potentially run this site
> ourselves as part of the CI setup, but that's trading the dependence
> on an external service for added CI maintenance burden on ourselves.
> 4. Docker/ubuntu repository fails. This happens occasionally -- the
> external repos will have transient connectivity issues. Not much we
> can do here except manually re-running the jobs.
> Is there anything I've missed?
There is also the occasional "QGIS is not compatible with the bleeding edge
[sip, name your dependency] version that [rolling distro] has decided to
start shipping today".
Matthias
> Nyall
> > Like proposed by Matthias, I would be very much in favor in modifying
> > our CI jobs to rely on non-rolling release distribution.
> > Regards,
> > Julien
> > > In my experience, the peer reviews have proven to be an effective tool
> to improve the code quality.
> > > I think it can be explained with a four eyes principle. The first two
> eyes are involved in writing the code, the second pair of eyes that
> validates
> > > needs to be a trusted pair.
> > > For a code base of the maturity of QGIS, this seems to me to be
> justified and reasonable.
> > > As for who can do a review, a potential conflict of interest has been
> raised. This arises most noticeable within a single company, but can also
> > > very well be the case whenever a collaboration occurs between multiple
> individuals or if a well-connected client is involved. In my experience, in
> > > most cases people will first ask the person that they trust to be most
> qualified to review a specific area of the code, regardless the organisation
> > > they work for. In some cases, this may be your colleagues. What I and
> others have done in the past in such cases, is to leave an additional review
> > > window of a couple of days before merging to give everyone the
> opportunity to jump in if they wanted to, just to be sure to play it fair.
> In my
> > > experience, this worked quite nicely, but I am also open to other
> approaches.
> > > As for failing tests, I think one possibly low hanging fruit would be
> to switch all CI workflows to be based on non-rolling distributions. And we
> > > could potentially also be a bit more strict with disabling flaky tests
> or making them optional.
> > > Best wishes
> > > Matthias
> > > On Tue, Oct 17, 2023 at 9:47 AM Sandro Santilli via QGIS-Developer <
> > >  On Tue, Oct 17, 2023 at 03:08:34PM +1300, Nyall Dawson via
> QGIS-Developer wrote:
> > >  > On Tue, 17 Oct 2023 at 03:41, Sandro Santilli <strk at kbt.io> wrote:
> > >  > > On Mon, Oct 16, 2023 at 09:59:35AM +1300, Nyall Dawson via
> > >  > > > If you flip the situation, you'll see that yes, you do have
> trust!
> > >  > > > - a complete stranger CANNOT approve their own changes
> > >  > > > - a complete stranger CANNOT approve other stranger's changes
> > >  > > > - a complete stranger CANNOT approve an approved member's
> changes
> > >  > > > vs
> > >  > > > - an approved member CANNOT approve their own changes
> > >  > > > - an approved member CAN approve a complete stranger's changes
> > >  > > > - an approved member CAN approve a another approved member's
> changes
> > >  > > That's partial trust. I'm trusted to be able to judge someone
> else's
> > >  > > work but not to judge my own work !
> > >  > Ok, it's partial trust. What's wrong with that?
> > >  I feel I'm not explaining myself correctly.
> > >  I do believe in peer review, and I'm happy for others to look at the
> > >  changes I propose. I'd love everyone to look at them!
> > >  The word "partial" was not appropriate, probably, it's more about
> > >  "inconsistency".
> > >  > In short: I'm more than OK with only partial trusting everyone. We
> ALL
> > >  > make mistakes, so let's stick with the processes we have which
> reduce
> > >  > the risk of these mistakes hitting end users..
> > >  I know I make mistakes, but I'm able to merge changes proposed by a
> > >  random contributor, where my own review is enough.
> > >  I'm FULLY trusted in that case, and this is conflicting with not
> > >  being so when it's me proposing the changes.
> > >  Why should I be able to merge in that case then ? Is it because
> > >  2 people review the code ? Me and the proponent ? Then why the
> > >  random contributor review would not count on MY prs ?
> > >  I hope you see the discrepancy here.
> > >  --strk;
> > >    Libre GIS consultant/developer
> > >    https://strk.kbt.io/services.html
> > >  _______________________________________________
> > >  QGIS-Developer mailing list
> > >  QGIS-Developer at lists.osgeo.org
> > >  List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > >  Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Julien Cabieces
> > Senior Developer at Oslandia
> > julien.cabieces at oslandia.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231018/b4134eb5/attachment-0001.htm>
