[QGIS-Developer] Mesh netcdf NaN visualisation in QGIS?
Aron Gergely aron.gergely at rasterra.nl
Tue Sep 5 06:17:12 PDT 2023
Are you also able to load data via the GDAL driver?
If so you could then try to show nodata using raster styling.
e.g.: make sure that Nodata is not set to transparent: go to the
raster's layer properties -> transparency, untick nodata value.
Then style in symbology settings.
Best regards,
Aron
On 04-09-2023 09:57, Richard Duivenvoorde via QGIS-Developer wrote:
> Hi,
> My colleague is creating netcdf as output of some other modelling
> software, and viewing/styling it in QGIS.
> In some places the modelling software goes awry and produces NaN's in
> de netcdf.
> Anybody an idea to create a visualisation (in QGIS) to find out WHICH
> part/cell's contain a NaN?
> output of ncdump:
>   0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0, 0,·
>     0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, NaNf, NaNf, NaNf,
> 0, 0,·
> 0, 0,·
> 0, 0,·
>     0, 0, 0, 0, 0, 0,
> Found:
> https://github.com/lutraconsulting/MDAL/blob/master/mdal/frmts/mdal_netcdf.cpp#L100-L102
> So apparently in MDAL this becomes
> "std::numeric_limits<double>::quiet_NaN"
> But how to find these in QGIS?
> Looking in Layer Styling I could use non-numbes (like None, NaN or
> whatever) in the inputs.
> Same in Mesh calculator.
> Any idea appreciated!
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Email Signature Kind Regards,
Aron Gergely
+31 (0) 6 38 70 97 66
*Rasterra* | www.rasterra.nl
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230905/d1ce61db/attachment.htm>
More information about the QGIS-Developer mailing list
