[Qgis-psc] Re: problems with the doc mailing list?
Otto Dassau
otto.dassau at gmx.de
Wed Apr 23 14:09:00 EDT 2008
On Wed, 23 Apr 2008 14:57:53 -0300
"Tim Sutton" <tim at linfiniti.com> wrote:
> Hi
> +1
> Do you not have admin rights? We should try to get you added to admin
> list if we can....I will only have time to do this on friday probably
> - hope that ok.
yes, friday would be ok and admin rights would be fine, too - also for the
future. We simply use the docs list as it is - no problem for now. I already
administrated servers before, but I am not very experienced with mailing lists,
only set up a few but never had to change/fix anything and don't want to damage
the doc list, so I can wait.
thanks
Otto
> Regards
> 2008/4/23, Otto Dassau <otto.dassau at gmx.de>:
> > Hi,
> > we plan to use the current qgis-doc mailing list for the new "community
team"
> > and therefore we would like to rename it into qgis-community-team. This
makes
> > sense, because the list will cover more than only the manual.
> > If we agree, can someone who has administration rights (Tim or Gary) write
a
> > mail to the lists and change the name?
> > + 1 Otto
> > thanks a lot
> > Otto
> > On Tue, 22 Apr 2008 11:31:05 -0300
> > > Hi
> > > What about renaming the doc list to qgis-community-team to show its
> > > more encompassing role and establishing some protocols to put a
> > > [DOC]
> > > [TRANSLATIONS]
> > > etc
> > > in the subject as appropriate (if people actually can be bothered to
> > > remember that though). In cases where the lists overlap, its probably
> > > a just cause for cross posting.
> > > Not sure if the above properly addresses your questions or is just a
> > > brainless ramble :-P
> > > Regards
> > > Tim
More information about the Qgis-psc
