[Fwd: Re: [Fwd: Re: [Qgis-psc] [Fwd: Re: [Qgis-developer] oracle raster plugin]]]
Tim Sutton tim at linfiniti.com
Wed Apr 15 02:38:19 PDT 2009
Hi
On Wed, Apr 15, 2009 at 8:43 AM, Marco Hugentobler
<marco.hugentobler at karto.baug.ethz.ch> wrote:
> Hi
> I had a quick look at the patch this morning.
> The patch seems ok to me and if there are no further objections, I'm going to
> apply it to trunk.
> However, in the longer term it would probably be good to have a unified loading
> dialog for rasters where file based and database GDAL datasources can be
> selected (similar to the vector ogr loading dialog). Tim, what is your opinion
> about this?
Yes this is absolutely where we should head towards. Also to allow
rasters with multiple subsets like hdf4:eos and hdf5:eos. I see there
is already a plugin for hdf4:eos in the repo.
+1 for you to commit this for the 'Pan' release.
Please note I will probably be out of contact for the next two days or so.
Regards
Tim
> Regards,
> Marco
> Am Dienstag 14 April 2009 19:05:04 schrieb Paolo Cavallini:
>> Hi all.
>> I'm forwarding the patch, but I also suggested Ivan to send it to the
>> -dev ML.
>> All the best.
>> -------- Messaggio Originale  --------
>> Oggetto: Re: [Fwd: Re: [Qgis-psc] [Fwd: Re: [Qgis-developer] oracle
>> raster plugin]]
>> Data: Tue, 14 Apr 2009 07:09:11 -0400
>> Da: Ivan Lucena <ivan.lucena at pmldnet.com>
>> >> I am using the plugin all the time now because it helped me to find a
>> >> bug in GDAL when loading a raster with pyramids. So right now I am
>> >> working on my code in GDAL/GeoRaster and I will send the patch after
>> >> that.
>> > You can submit a bugfix later, but it's important that it goes in before
>> > feature freeze.
>> The bug that I am working on is on GDAL GeoRaster driver source code.
>> The plugin itself is working fine.
>> >> Thanks a lot,
>> > Thanks to you, rather!
>> There is PNG icon that is not included on the diff file and I don't know
>> how I would send it other
>> than by a attachment on a e-mail.
>> My best regards,
>> Ivan
> Dr. Marco Hugentobler
> Institute of Cartography
> ETH Zurich
> Technical Advisor QGIS Project Steering Committee
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
More information about the Qgis-psc mailing list
