[Qgis-psc] grant write permissions for new manual contributors
Tim Sutton tim at linfiniti.com
Thu Apr 21 03:00:41 PDT 2011
Hi
2011/4/21 Otto Dassau <dassau at gbd-consult.de>:
> Hi,
> it works now again - thanks Tim!
Ok good to hear!
Regards
Tim
> Regards,
>  Otto
> Am Thu, 21 Apr 2011 09:21:23 +0200
> schrieb Otto Dassau <dassau at gbd-consult.de>:
>> Hi,
>> some time ago I applied at SAC to be able to grant write permissions for
>> new manual contributors to the qgis docs repository. Here is the thread:
>> http://osgeo-org.1803224.n2.nabble.com/OSGeo-588-request-for-write-permissions-to-add-new-svn-members-td5167347.html
>> When I try to login to the OSGEO web, it seems that ID odassau no longer
>> exist and I don't have a pw for it anyway. Message is: "Sorry, odassau is
>> not recognized as a user name or an email address."
>> According to the SAC answer, following has to be done for my OSGEO ID
>> dassau.
>> You have commit access because you are a member of the 'qgis' group, which
>> presumably has repository-wide access. You are not a member of the
>> qgis_docs group; until that is the case, you can not add others to the
>> qgis_docs group. Once you are, you will see an "Add" button at the bottom
>> of the group page via which you can add people through.
>> Asking an existing member of the qgis_docs group is the way to get into
>> that group.
>> Can somebody do this for me, so I can add others to the qgis_docs group?
>> And maybe remove odassau from the group, if it is still there?
>> Thanks, Otto
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
More information about the Qgis-psc mailing list
