[Qgis-psc] grant write permissions for new manual contributors
Otto Dassau dassau at gbd-consult.de
Thu Apr 21 02:54:01 PDT 2011
it works now again - thanks Tim!
Regards,
 Otto
Am Thu, 21 Apr 2011 09:21:23 +0200
schrieb Otto Dassau <dassau at gbd-consult.de>:
> Hi,
> some time ago I applied at SAC to be able to grant write permissions for
> new manual contributors to the qgis docs repository. Here is the thread:
> http://osgeo-org.1803224.n2.nabble.com/OSGeo-588-request-for-write-permissions-to-add-new-svn-members-td5167347.html
> When I try to login to the OSGEO web, it seems that ID odassau no longer
> exist and I don't have a pw for it anyway. Message is: "Sorry, odassau is
> not recognized as a user name or an email address."
> According to the SAC answer, following has to be done for my OSGEO ID
> dassau.
> You have commit access because you are a member of the 'qgis' group, which
> presumably has repository-wide access. You are not a member of the
> qgis_docs group; until that is the case, you can not add others to the
> qgis_docs group. Once you are, you will see an "Add" button at the bottom
> of the group page via which you can add people through.
> Asking an existing member of the qgis_docs group is the way to get into
> that group.
> Can somebody do this for me, so I can add others to the qgis_docs group?
> And maybe remove odassau from the group, if it is still there?
> Thanks, Otto
More information about the Qgis-psc mailing list
