[Qgis-psc] RFC for Data Frames
Benedict Holland benedict.m.holland at gmail.com
Thu Jan 10 08:48:31 PST 2013
Marco,
I like this suggestion. This can also be written in a way with a data frame
like object in mind and I can add linking layer extents to layers which can
be moved later to the parent object. Having a list of layers which are
displayed is a small UI change and would default to behave like it does
now. As an introductory project do you think this would be doable? This
would also allow time to solidify the data frames concept for the 3.0 push
or get in most api changes into 3.0.
I will write up an RFC and post it shortly and update the RFC for data
frames to reflect the most recent conversations.
~Ben
On Thu, Jan 10, 2013 at 10:02 AM, Marco Hugentobler <
marco.hugentobler at sourcepole.ch> wrote:
>  Hi Benedict
> >The huge downside to this is that a change like this could break a lot
> more code than a smaller change like just having the data frame be a simple
> collection of layers. I would be impacting quite a lot >of code with these
> changes. I am not familiar enough with how a canvas is actually displayed
> yet or how the composer displays objects to know if my changes would force
> a lot of changes. I don't >particularly want to be rewriting most of
> QgsCore as a first project, alone.
> Yes, I agree. Changing the logic between QgsProject and QgsMapLayer has a
> lot of side effects. In my opinion it is not an ideal first project.
> If you are mainly interested in having multiple maps in composer, you
> could as well modify QgsComposerMap / -Widget with a possibility to select
> the layers you want in the composer map. Like that, you could embed groups
> / layers from other projects into the map canvas and, in print composer,
> create maps with different layer sets.
> I know this does not replace the need of having multiple views / datasets
> some day, but it is an approach without modifying a lot of core classes.
> Regards,
> Marco
> On 09.01.2013 20:47, Benedict Holland wrote:
> Hi all,
>  So this then asks a fairly fundamental question: what exactly would I be
> developing? The data frame could handle rendering but I suppose that it
> would just be a question of if want the QgsProject to handle it or push it
> down a level. I like the idea of data frames handling it the more I think
> about it however. This would actually closely mimic what the QgsProject
> does currently. If we go down this route, would it be fair to call it a
> subproject ie QgsSubproject? I think that this would fully encapsulate the
> idea that I am creating a way to generate projects which would have
> multiple layers, link to different subprojects, have a canvas, legend,
> display properties, interactions with the Composer, etc. I like this name
> also because it has a direct link to QgsProject in that a QgsProject is
> made up of QgsSubproject objects. This is a logical grouping which makes
> more sense than data frames.
> collection of layers. I would be impacting quite a lot of code with these
> a lot of changes. I don't particularly want to be rewriting most of QgsCore
>  Also a huge problem that I see with this project is that I don't have a
> good way of coding in the way that is specified in the CODING doc where I
> would have something like load() loadNew() because I
> am fundamentally changing what entire classes do and how they relate to
> each other. If no one else is working in this area then I can basically do
> what needs to be done but merging code when object relationships change is
> very difficult and I have not seen a great way to manage that process. If
> there are no complaints then I will edit the RFC to reflect the
> QgsSubproject principal and send out an updated RFC to the list serve.
>  Thanks,
> ~Ben
> On Wed, Jan 9, 2013 at 11:15 AM, Marco Hugentobler <
>>  Hi Benedict
>> It is a good direction to go towards multiple views / dataframes. This is
>> a frequent feature-wish and it is good to know someone is working on it.
>> The RFC is centered around data frames as layer collections, but I think
>> it would involve more than just QgsProject and QgsMapLayer. E.g. every
>> frame could have it's own canvas / layer set / output crs (maybe even
>> legend, overview map). Therefore, the term data frame may need to be
>> changed.
>> Once you are working on QgsProject, don't forget that layers and whole
>> groups can be embedded from other projects / frames.
>> Regards,
>> Marco
>> On 09.01.2013 01:04, Benedict Holland wrote:
>>  Hi All,
>>  I don't know if I can actually call this project data frames as I don't
>> know if that is TMed by ESRI but regardless the concept is the same. The
>> RFC is located here:
>>  http://hub.qgis.org/wiki/quantum-gis/Data_Frames
>>  This would be a substantial change to the current architecture of
>> QgsProjects and the relationship between QgsProjects and QgsMapLayers. I
>> have been a professional developer for about 6 years or so and have worked
>> on projects much larger than this but not in c++ for quite some time. I do
>> though use best practices including unit tests and documentation as part of
>> a standard development procedure and I applaud your requirements that these
>> be included in this feature. While I do expect this will change
>> the architecture I do not expect much will break unless previous releases
>> cannot load a project file from a future release but honestly, there is
>> little I or anyone else can do about that now except tell people to
>> upgrade. If there isn't currently a way to handle future releases then I
>> will also create a method for doing that and file it under the same RFC
>> linked above.
>>  Let me know what you can think. I am eager to get working on this as it
>> would make life substantialy easier for me in the direct future.
>> ~Ben Holland
>>  _______________________________________________
>> Qgis-psc mailing listQgis-psc at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-psc
>> Dr. Marco Hugentobler
>> Sourcepole -  Linux & Open Source Solutions
>> Weberstrasse 5, CH-8004 Zürich, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20130110/5df35a9e/attachment.html>
More information about the Qgis-psc mailing list
