[Qgis-psc] RFC for Data Frames
Marco Hugentobler marco.hugentobler at sourcepole.ch
Fri Jan 11 01:20:17 PST 2013
Hi Benedict
 >As an introductory project do you think this would be doable?
Yes, I think this would provide a nice functionality and it is a good
introductory project while the frame/subproject/view discussion is going on.
Regards,
Marco
On 10.01.2013 17:48, Benedict Holland wrote:
> Marco,
> I like this suggestion. This can also be written in a way with a data
> frame like object in mind and I can add linking layer extents to
> layers which can be moved later to the parent object. Having a list of
> layers which are displayed is a small UI change and would default to
> behave like it does now. As an introductory project do you think this
> would be doable? This would also allow time to solidify the data
> frames concept for the 3.0 push or get in most api changes into 3.0.
> I will write up an RFC and post it shortly and update the RFC for data
> frames to reflect the most recent conversations.
> ~Ben
> On Thu, Jan 10, 2013 at 10:02 AM, Marco Hugentobler
> <marco.hugentobler at sourcepole.ch
> <mailto:marco.hugentobler at sourcepole.ch>> wrote:
>     Hi Benedict
>     >The huge downside to this is that a change like this could break
>     a lot more code than a smaller change like just having the data
>     frame be a simple collection of layers. I would be impacting quite
>     a lot >of code with these changes. I am not familiar enough with
>     how a canvas is actually displayed yet or how the composer
>     displays objects to know if my changes would force a lot of
>     changes. I don't >particularly want to be rewriting most of
>     QgsCore as a first project, alone.
>     Yes, I agree. Changing the logic between QgsProject and
>     QgsMapLayer has a lot of side effects. In my opinion it is not an
>     ideal first project.
>     If you are mainly interested in having multiple maps in composer,
>     you could as well modify QgsComposerMap / -Widget with a
>     possibility to select the layers you want in the composer map.
>     Like that, you could embed groups / layers from other projects
>     into the map canvas and, in print composer, create maps with
>     different layer sets.
>     I know this does not replace the need of having multiple views /
>     datasets some day, but it is an approach without modifying a lot
>     of core classes.
>     Regards,
>     Marco
>     On 09.01.2013 20:47, Benedict Holland wrote:
>>     Hi all,
>>     So this then asks a fairly fundamental question: what exactly
>>     would I be developing? The data frame could handle rendering but
>>     I suppose that it would just be a question of if want the
>>     QgsProject to handle it or push it down a level. I like the idea
>>     of data frames handling it the more I think about it however.
>>     This would actually closely mimic what the QgsProject does
>>     currently. If we go down this route, would it be fair to call it
>>     a subproject ie QgsSubproject? I think that this would
>>     fully encapsulate the idea that I am creating a way to generate
>>     projects which would have multiple layers, link to different
>>     subprojects, have a canvas, legend, display properties,
>>     interactions with the Composer, etc. I like this name also
>>     because it has a direct link to QgsProject in that a QgsProject
>>     is made up of QgsSubproject objects. This is a logical grouping
>>     which makes more sense than data frames.
>>     quite a lot of code with these changes. I am not familiar enough
>>     with how a canvas is actually displayed yet or how the composer
>>     changes. I don't particularly want to be rewriting most of
>>     Also a huge problem that I see with this project is that I don't
>>     have a good way of coding in the way that is specified in the
>>     CODING doc where I would have something like load() loadNew()
>>     because I am fundamentally changing what entire classes do and
>>     how they relate to each other. If no one else is working in this
>>     area then I can basically do what needs to be done but merging
>>     code when object relationships change is very difficult and I
>>     have not seen a great way to manage that process. If there are no
>>     complaints then I will edit the RFC to reflect the
>>     QgsSubproject principal and send out an updated RFC to the list
>>     serve.
>>     Thanks,
>>     ~Ben
>>     On Wed, Jan 9, 2013 at 11:15 AM, Marco Hugentobler
>>         Hi Benedict
>>         It is a good direction to go towards multiple views /
>>         dataframes. This is a frequent feature-wish and it is good to
>>         know someone is working on it.
>>         The RFC is centered around data frames as layer collections,
>>         but I think it would involve more than just QgsProject and
>>         QgsMapLayer. E.g. every frame could have it's own canvas /
>>         layer set / output crs (maybe even legend, overview map).
>>         Therefore, the term data frame may need to be changed.
>>         Once you are working on QgsProject, don't forget that layers
>>         and whole groups can be embedded from other projects / frames.
>>         Regards,
>>         Marco
>>         On 09.01.2013 01:04, Benedict Holland wrote:
>>>         Hi All,
>>>         I don't know if I can actually call this project data frames
>>>         as I don't know if that is TMed by ESRI but regardless the
>>>         concept is the same. The RFC is located here:
>>>         http://hub.qgis.org/wiki/quantum-gis/Data_Frames
>>>         This would be a substantial change to the
>>>         current architecture of QgsProjects and the relationship
>>>         between QgsProjects and QgsMapLayers. I have been a
>>>         professional developer for about 6 years or so and have
>>>         worked on projects much larger than this but not in c++ for
>>>         quite some time. I do though use best practices including
>>>         unit tests and documentation as part of a standard
>>>         development procedure and I applaud your requirements that
>>>         these be included in this feature. While I do expect this
>>>         will change the architecture I do not expect much will break
>>>         unless previous releases cannot load a project file from a
>>>         future release but honestly, there is little I or anyone
>>>         else can do about that now except tell people to upgrade. If
>>>         there isn't currently a way to handle future releases then I
>>>         will also create a method for doing that and file it under
>>>         the same RFC linked above.
>>>         Let me know what you can think. I am eager to get working on
>>>         this as it would make life substantialy easier for me in the
>>>         direct future.
>>>         ~Ben Holland
>>>         _______________________________________________
>>>         Qgis-psc mailing list
>>>         Qgis-psc at lists.osgeo.org  <mailto:Qgis-psc at lists.osgeo.org>
>>>         http://lists.osgeo.org/mailman/listinfo/qgis-psc
>>         Dr. Marco Hugentobler
>>         Sourcepole -  Linux & Open Source Solutions
>>         Weberstrasse 5, CH-8004 Zürich, Switzerland
>>         marco.hugentobler at sourcepole.ch  <mailto:marco.hugentobler at sourcepole.ch>  http://www.sourcepole.ch
>>         Technical Advisor QGIS Project Steering Committee
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20130111/45f67585/attachment.html>
More information about the Qgis-psc mailing list
