[Qgis-psc] Enable travis on QGIS projectr
Tim Sutton tim at kartoza.com
Sat Nov 15 12:34:19 PST 2014
Hi Matthias
On Fri, Nov 14, 2014 at 8:19 PM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> Dear Tim, Testing and QA manager
> Dear PSC
> The last days I have been busy to get the test suite into a state where
> it can be used for continuous integration.
​Great - thanks for this!​
> Currently almost all tests are passing. Some bugs could be fixed.
> Some are disabled because:
>  * There is a problem with them that needs to be addressed like a crash
> on exit on this particular platform
>  * There are pull requests pending with patches I did not dare to apply
> myself but will make the test pass (and hopefully improve the source code).
​Ok​
> While I am able to push the changes required to fix the tests and the
> requires file that tells travis how to build and test the project I
> don't have the admin rights to give travis access to the necessary hooks.
> I would therefore like to ask the PSC to either enable this service for
> the QGIS repository on the travis-ci homepage or assign me the necessary
> rights on the QGIS repository to pull the handle myself.
​Ok I enabled it on travis with these settings:
[image: Inline image 1]​
> Thank you very much for your consideration, I hope this effort helps to
> improve stability of QGIS in the long run,
​Thanks very much for your work on this - we use travis auto tests on PR in
InaSAFE and it works really well so I am looking forward to seeing the same
set up in place for QGIS. As a follow on we need to mandate that no PR
should be accepted that does not have passing tests in Travis as per your
QEp-5.
Regards
Tim​
> Matthias
Tim Sutton
Visit http://kartoza.com to find out about open source:
 * Desktop GIS programming services
 * Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20141115/24a3aac0/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20141115/24a3aac0/attachment.jpg>
More information about the Qgis-psc mailing list
