[Qgis-psc] spam in Redmine :-(
Tim Sutton tim at kartoza.com
Fri Dec 1 02:23:30 PST 2017
Hi
Thanks for your comments Nyall, Nathan and Matthias. It seems that the user agent is rather easy to do:
https://wiki.qt.io/How_to_set_user_agent_in_Qt_application
So it should automatically add QGIS and the current version to the header. And for an apache rule we could use a regex like this on the redline signup page:
https://serverfault.com/a/749446
(Replacing SetEnvIfNoCase with SetEnvIfCase)
I would propose that we try to build this quickly (sounds like a good use of QGIS funds??) and get it done as a feature freeze exception. Then we just need something on redline saying that you need to sign up from in QGIS.
Regards
Tim
> On 01 Dec 2017, at 11:37, Matthias Kuhn <matthias at opengis.ch> wrote:
>> ​OR have users submit bugs easily AND have no spam. In case it wasnt clear above, my proposal above advocates ditching mantras in favour of a 'normal' sign up process​ but the process has to happen through a QGIS browser agent. I reckon that is a pretty low friction approach.
>> WRT Nathan;s comment about GitHub, while I am +1 about using  github as an option to sign in, my experience is that signing up for github is just as obscure for 'normal' users as a mantra, so if we are going to make users sign up for one more thing, hub.qgis.org <http://hub.qgis.org/> should be that thing.... In summary my preference is:
>> * Make it convenient for *everyone* to file tickets
>> * Kill the mantra - it is the most un-user friendly experience we could give people
>> * Make the initial sign up happen through a browser embedded in QGIS to prevent spammers. Within that sign up:
>>     * Support github authentication if we can to make it easy for geeks
>>     * Support sign up through local user database in redmine still
> Thanks Tim,
> I have the same preferences,
> Having a painless option to signup through QGIS itself and thus make it less spam-prone sounds great.
> We probably still need a "classic" signup way through webpages for the "I can't signup because my QGIS crashes on start scenario" and that would be solved by the github, other oAuth or osgeo login.
> Regards
> Matthias
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Tim Sutton
QGIS Project Steering Committee Chair
tim at qgis.org
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171201/140b6674/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171201/140b6674/attachment.png>
More information about the Qgis-psc mailing list
