[Qgis-psc] Websites moved + https
Paolo Cavallini cavallini at faunalia.it
Sun Dec 3 04:42:41 PST 2017
Huge thanks!
Il 3 dicembre 2017 14:13:51 GMT+02:00, Richard Duivenvoorde <rdmailings at duif.net> ha scritto:
>Hi,
>We moved
>qgis.org/www.qgis.org/version.qgis.org
>and
>doc.qgis.org
>from the old osgeo server to qgis2, the Hetzner server where
>plugins.qgis.org iss also running.
>FYI issues.qgis.org is running on qgis3
>We also tested/used Letsencrypt certificate because the Globalsign cert
>was almost expired.
>See:
>https://qgis.org
>https://plugins.qgis.org
>(all let's encrypt now)
>I thought to disable http traffic for both, so
>http://qgis.org is redirected to https:/qgis.org
>(the standard Letsencrypt way, with some rewrite rules)
>I also did that for plugins.qgis.org, but then people started to have
>issues with installing plugins, so I reverted that for now, and will
>report an issue around that.
>Documentation is not yet https, not sure about that.
>To me qgis.org/api is now much much faster \o/
>IF you have troubles or see problems, please report back to
>admin at qgis.org
>TODO:
>- bring letsencrypt to issues.qgis.org
>- fix plugins.qgis.org https problem
>- bring test.qgis.org to qgis2
>- check github hooks
>Regards,
>_______________________________________________
>Qgis-psc mailing list
>Qgis-psc at lists.osgeo.org
>https://lists.osgeo.org/mailman/listinfo/qgis-psc
Sent from mobile. Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171203/02a46da3/attachment.html>
More information about the Qgis-psc mailing list
