[Qgis-psc] QGIS for Mac OS packaging and infrastructure
Peter Petrik peter.petrik at lutraconsulting.co.uk
Wed Feb 20 07:14:02 PST 2019
thank you and let me add my estimates
- Lack of Python support for macOS 10.11 and 10.12 This is very highly
uncertain task since I got no response from python comunity (
https://bugs.python.org/issue31601) and I will need to do some tests if I
can somehow work around it. My preference is to have 1 day for
investigation to come up with the solution/workaround or at least
understand the scope of the issue.
- Unable to transfer of the infrastructure and automatic builds under
QGIS.org Assuming we have working Mojave server with remote desktop access,
certificate and dropbox ready, it would take a day to finish the
documentation of the package and another day to install the packager to the
new server.
- from Tim: Ability to add python packages (maybe adding another python
path to directory in the user’s current profile path
This is trivial change for few minutes.
Kind regards,
Peter
On Wed, Feb 20, 2019 at 2:54 PM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Saber,
> There was discussion to help fund the remaining "severe" issues you have
> around the MacOS builds.
> Can you provide us estimates on how much funds are needed to finish the
> following three items (skipping the GRASS issues for now - can be handled
> later):
> - Lack of Python support for macOS 10.11 and 10.12 - Unable to transfer of
> the infrastructure and automatic builds under QGIS.org - from Tim: Ability
> to add python packages (maybe adding another python path to directory in
> With respect to additional small donations I got: this adds up to approx
> 100-200 € earmarked towards MacOS. I can forward this to Lutra, however, if
> the PSC decides, we might also fund more, so you are able to finish the
> above three items.
> With respect to Tim's crash:
> - Getting a crash when trying to move dock widgets around (in current LTR
> build)
> Is there a ticket? If yes, this can be handled during the normal bug
> fixing cycles. We just treat MacOS like all the other platforms. Nothing
> special about it.
> Greetings,
> Andreas
> Am 20.02.19 um 13:11 schrieb Saber Razmjooei:
> Dear PSC, Following our earlier email about QGIS packages for macOS, we
> ran a crowdfunding campaign. Unfortunately, we did not raise enough fund to
> carry out the work we had intended. We had to reduce the scope of our work.
> Below are the known issues/limitations: - Lack of Python support for macOS
> 10.11 and 10.12 - Unable to transfer of the infrastructure and automatic
> builds under QGIS.org - GRASS support in the Processing toolbox: most of
> the modules should work. But GRASS 7.6 is not fully compatible with Python
> 3.x and hence some of the algorithms might fail. This will be fixed after
> GRASS 7.8 release. For more details, see here:
> https://www.lutraconsulting.co.uk/blog/2019/02/19/qgis-for-macos-update/
> https://lutraconsulting.github.io/qgis-mac-packager/ If you’d like to
> publish the packages, we will need the server details where you’d like us
> to upload the binaries. If the build infrastructure should be moved under
> QGIS.org, we will need QGIS (OSGeo) Apple Developers Certificate, macOS
> Mojave Server with right to install XCode and related packages and funds to
> clean, document and deploy packaging code to the official server. Kind
> regards Saber
> On Thu, 10 Jan 2019 at 07:10, Larry Shaffer <larrys at dakotacarto.com>
> wrote:
>> Hi Nyall, et al.,
>> On Thu, Dec 13, 2018 at 3:16 PM Nyall Dawson <nyall.dawson at gmail.com>
>> wrote:
>>> On Fri, 14 Dec 2018 at 07:42, Tim Sutton <tim at kartoza.com> wrote:
>>> > Hi
>>> > Ah you are right - thanks! I see the QGIS group widgets have an issue
>>> with tehtext staying black in dark mode whilst native Qt widgets correctly
>>> show their text in white.
>>> It's this line:
>>> https://github.com/qgis/QGIS/blob/master/src/app/qgisappstylesheet.cpp#L130
>>> I suspect ALL of that custom group box styling should be removed.
>>> Trawling through the git history it's over 6 years old, and I strongly
>>> suspect that the original styling issues it was designed to workaround
>>> are no longer a problem (and that the custom styling is causing more
>>> issues now than it is fixing)
>> Indeed. That effort was to bridge issues with different platforms, in an
>> attempt to make things look similar. It is no doubt antiquated by now.
>> Regards,
>> Larry Shaffer
>> Dakota Cartography
>> Black Hills, South Dakota
>> Nyall
>>> > Regards
>>> > Tim
>>> > On Thu, Dec 13, 2018 at 5:29 PM Denis Rouzaud <denis.rouzaud at gmail.com>
>>> wrote:
>>> >> Hi Tim,
>>> >> Are you sure it's the QGIS night mapping theme and not the new look
>>> of Qt for Dark Theme?
>>> >> Cheers,
>>> >> Denis
>>> >> Le jeu. 13 déc. 2018 à 11:14, Tim Sutton <tim at kartoza.com> a écrit :
>>> >>> Hi
>>> >>> Tested with 3.4.2 from last night - still stuck in night mapping
>>> mode :-(
>>> >>> Regards
>>> >>> Tim
>>> >>> On 13 Dec 2018, at 10:31, Tim Sutton <tim at kartoza.com> wrote:
>>> >>> Hi
>>> >>> Brilliant thanks - downloading now!
>>> >>> Regards
>>> >>> Tim
>>> >>> On 13 Dec 2018, at 09:16, Saber Razmjooei <
>>> saber.razmjooei at lutraconsulting.co.uk> wrote:
>>> >>> Hi Tim,
>>> >>> Both 3.4.2 and master are now built with Qt 5.12. Feel free to give
>>> them a try and let us know if you have any other issues.
>>> >>> Cheers
>>> >>> Saber
>>> >>> On Tue, 11 Dec 2018 at 19:24, Tim Sutton <tim at kartoza.com> wrote:
>>> >>>> Cool, thanks!
>>> >>>> On Tue, Dec 11, 2018 at 5:34 PM Peter Petrik <
>>> peter.petrik at lutraconsulting.co.uk> wrote:
>>> >>>>> qt 5.12 is on my list too:) But both of these are rather small
>>> issues with < 1/2 day to solve.
>>> >>>>> P.
>>> >>>>> On Tue, Dec 11, 2018 at 3:14 PM Denis Rouzaud <
>>> denis.rouzaud at gmail.com> wrote:
>>> >>>>>> Hi all,
>>> >>>>>> I would propose not to offer multiple installer. The situation is
>>> already complex enough. We should at least clearly promote one as the
>>> default one.
>>> >>>>>> Regarding the night mapping theme, it is a very short time issue
>>> (QGIS is unusable in default theme under Mac OS with Dark Theme with Qt <
>>> 5.12).
>>> >>>>>> I have just updated to Qt 5.12, I am automatically back to
>>> default theme and it looks much better!
>>> >>>>>> Cheers,
>>> >>>>>> Denis
>>> >>>>>> Le mar. 11 déc. 2018 à 09:18, Tim Sutton <tim at kartoza.com> a
>>> écrit :
>>> >>>>>>> Hi
>>> >>>>>>> On 11 Dec 2018, at 09:42, Saber Razmjooei <
>>> >>>>>>> Dear PSC,
>>> >>>>>>> From the meeting notes [1], it seems the motion for the PSC to
>>> absorb the cost (Point 2 in my email) has been accepted.
>>> >>>>>>> Could you clarify:
>>> >>>>>>> 1- The PSC is not funding the initial work (Point 1). If so,
>>> we'd like to run a crowd-funding campaign. Any promotion from QGIS.org is
>>> highly appreciated.
>>> >>>>>>> 2- From 3.6 release, the packages generated from the above
>>> packaging process will be used under the official download page. This is
>>> for our resourcing and crowd-funding purposes, so that we can have
>>> everything in place before 3.6 release.
>>> >>>>>>> Just on this, can I propose we put both your and William’s
>>> packages there for the time being? There are some technical differences
>>> between the packaging approaches that mean that some users may seek out
>>> specifically Williams or Lutra’s packages. My understanding from William is
>>> that some of these can be resolved while others cannot easily. For example
>>> you cannot install pip packages into the QGIS code signed bundle. Currently
>>> with the Lutra packages I am still locked into night mapping theme which I
>>> need to file a ticket about still :-P We could collaboratively provide some
>>> test with the download outlining which installer is appropriate for which
>>> user type.
>>> >>>>>>> Regards
>>> >>>>>>> Tim
>>> >>>>>>> Tim Sutton
>>> >>>>>>> tim at qgis.org
>>> >>>>>>> _______________________________________________
>>> >>>>>>> Qgis-psc mailing list
>>> >>>>>>> Qgis-psc at lists.osgeo.org
>>> >>>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
>>> >>>>>> Denis Rouzaud
>>> >>>>>> denis at opengis.ch
>>> >>>>>> +41 76 370 21 22
>>> >>>> Tim Sutton
>>> >>>> Visit http://kartoza.com to find out about open source:
>>> >>>>  * Desktop GIS programming services
>>> >>>>  * Geospatial web development
>>> >>>> * GIS Training
>>> >>>> * Consulting Services
>>> >>>> Skype: timlinux Irc: timlinux on #qgis at freenode.net
>>> >>>> Tim is a member of the QGIS Project Steering Committee
>>> >>>> Kartoza is a merger between Linfiniti and Afrispatial
>>> >>> Saber Razmjooei
>>> >>> +44 (0)7568 129733
>>> >>> <KartozaNewLogoThumbnail.jpg>
>>> >>> Tim Sutton
>>> >>> Co-founder: Kartoza
>>> >>> Ex Project chair: QGIS.org
>>> >>> GIS Training
>>> >>> Consulting Services
>>> >>> Skype: timlinux
>>> >>> IRC: timlinux on #qgis at freenode.net
>>> >>> Tim Sutton
>>> >>> Co-founder: Kartoza
>>> >>> GIS Training
>>> >>> Consulting Services
>>> >>> Skype: timlinux
>>> >> Denis Rouzaud
>>> >> denis at opengis.ch
>>> >> +41 76 370 21 22
>>> > Tim Sutton
>>> > * GIS Training
> Saber Razmjooei
> +44 (0)7568 129733
> Qgis-psc mailing listQgis-psc at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20190220/8e0760e3/attachment.html>
More information about the Qgis-psc mailing list
