[Qgis-psc] [QGIS-Developer] Direct push forbidden to master
Matthias Kuhn matthias at opengis.ch
Sun Nov 10 03:51:34 PST 2019
On 11/10/19 12:49 PM, Alessandro Pasotti wrote:
> On Sun, Nov 10, 2019 at 11:54 AM Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
>     On 11/10/19 11:42 AM, Sandro Santilli wrote:
>>     On Sun, Nov 10, 2019 at 09:20:11AM +0100, Alessandro Pasotti wrote:
>>>     Just one thing I would recommend investing a bit more time and money: to be
>>>     able to run a Travis-like test suite locally
>>     +1
>>     I can't remember the last time I had a successful `make check`, bust
>>     must be decades ago... Improving the ability for devs to run testsuite
>>     locally is a huge asset. I think it goes along the lines of:
>>        - Only run tests that can be run on the machine, given the available deps
>>          ... and WARN at build/test time about tests being skipped,
>>          to hint developer about improving the test coverage
>>        - Ensure running the tests doesn't mess up with your worktree
>>          Seehttps://github.com/qgis/QGIS/pull/31980
>>        - Make it easy for devs to run single, specific tests, to help
>>          when changing a single specific spot of the codebase
>     See
>     https://docs.qgis.org/testing/en/docs/developers_guide/unittesting.html#run-your-tests
>     , it says
>     > If a test fails, you can use the ctest command to examine more
>     closely why it failed. Use the |-R| option to specify a regex for
>     which tests you want to run and |-V| to get verbose output:
>     > $ ctest -R appl -V
>     Is there more required?
> That's unfortunately not enough, what I was talking about it run test
> locally in the exactly same environment that Travis uses, I tried to
> document part of the workflow in
> https://github.com/qgis/QGIS/tree/master/.docker but that's not enough
> to run the tests (I mean all of them including spelling, clazy and all
> the other checks that are run on Travis and that are not in the
> pre-commit hook).
> There are times when being able to run Travis locally and
> interactively ssh into the containers a make changes is the only option.
> So, first thing is to have a pre-commit that runs **all** the checks
> that are run on Travis, second is to be able to execute Travis
> environment locally.
Sorry, I was a bit unclear. That was just meant for the last item in
your list.
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20191110/2851dee8/attachment.html>
More information about the Qgis-psc mailing list
