[Qgis-psc] [QGIS-Developer] Direct push forbidden to master
    Sandro Santilli
    strk at kbt.io
    Sun Nov 10 05:39:01 PST 2019
On Sun, Nov 10, 2019 at 12:51:34PM +0100, Matthias Kuhn wrote:
> Sorry, I was a bit unclear. That was just meant for the last item in your
> list.
For clarity: the list was mine :)
I do undertand Alessandro's point: being able to run
the _same_ tests run by the CI guarding protected branches.
This would be easy with Drone-CI (free software).
There's a public cloud.drone.io service which does work
against github, if we want to try going that way.
Advantage would be that running the _same_ tests would
be as simple as running:
  drone exec
>From within the source tree.
Installing "drone" is a matter of instaling a single
binary, or, if you have `go` dev environment setup,
running a single `go install` command.
Reference: https://drone.io/
--strk;
More information about the Qgis-psc
