[Qgis-psc] [QGIS-Developer] Documentation bot
DelazJ delazj at gmail.com
Mon Jan 6 17:59:46 PST 2020
Hi all,
Thanks Denis for the work.
I might be missing some key points because comparing the generated reports
from the two systems, I'm sorry I feel like it's instead a regression. Alow
me to explain:
1. For the same feature merged in the code, see old system report [0] vs
new system's [1]. From a doc writer perspective, I get more information
from the first one than the second.
2. Another point is that milestone is what we use to filter issues reports
and manage the docs schedule, so if it's not set by the developer (assuming
that the dev knows the milestone to indicate), someone has to do it
manually in the generated report. With the current system, when we enter a
new development cycle, we (Richard and myself) set the new milestone (for
LTR) and the target version label [2] and then, every generated report is
automatically filled with these information at their creation. Done once
and nobody cares about anymore. Until the next release.
This new system means devs "should" enter that information for each
doc-related PR. I can't count the number of times I made a remind for the
[needs-docs] label, and the PR was merged without...
3. What is meant by "developers should take care of it"? When/where will
the details of the feature be available? If the dev wants to write about
his changes in our docs, OK. Otherwise, are we not overloading their
workload while they could have provided the necessary bits in the commit
message, as they should be doing currently.
What I understood from the proposal is that developers will be encouraged
to detail their feature in the PR message, the place they sell their
feature to others, using a simple and accessible language. And then, at the
merge time, the message of the PR (with maybe screenshots) will be copied
to the generated report in docs, allowing writers to see what the feature
is. Did I misunderstand or have the options changed meanwhile?
Sorry if I'm less joyful than others (I'm not comfortable to comment a work
I could not be able to do, and in English - so sorry if some words/tone
seem used inappropriately) but from a doc repository manager pov, I'm
envisioning more work and less information than we wished. For both writers
and devs. and I wish I'm wrong.
For developers, what does it make easier to you? Nyall, I find your
features very easy and pleasant to document given that  doc related changes
are clearly separated and fully described for writers (see eg [3] which
generate [4][5][6] ) so I'm a bit lost reading your comment above. What
would this improve for you? Btw I wonder what/how this PR in [3] would have
generated as issue report(s) in the doc repository with the new system?
[0] https://github.com/qgis/QGIS-Documentation/issues/4740
[1] https://github.com/qgis/QGIS-Documentation/issues/4741
[2]
https://github.com/qgis/QGIS-Sysadmin/blob/master/webhooks/github_feature_tracker.cgi#L446
[3] https://github.com/qgis/QGIS/pull/33496/commits
[4] https://github.com/qgis/QGIS-Documentation/issues/4689
[5] https://github.com/qgis/QGIS-Documentation/issues/4690
[6] https://github.com/qgis/QGIS-Documentation/issues/4691
Regards,
Harrissou
Le mar. 7 janv. 2020 à 00:39, Nyall Dawson <nyall.dawson at gmail.com> a
écrit :
> On Mon, 6 Jan 2020 at 22:57, Denis Rouzaud <denis.rouzaud at gmail.com>
> wrote:
> > Dear Devs,
> > This is a report for the QGIS grant proposal to create a documentation
> bot.
> > This bot is now alive and automatically create an issue in the
> documentation repo for merged PR.
> > ** How to use it **
> > 1) Create a PR on qgis/QGIS
> > 2) tag it with "Needs Documentation"
> > 3) optionally set the milestone to it
> > 4) merge it
> > => an issue is automatically created in the qgis/QGIS-Documentation
> repository
> > => you get a message telling you should take care of it
> Really cool - great work. This should make things much easier to manage!
> Nyall
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200107/565cef20/attachment.html>
More information about the Qgis-psc mailing list
