[Qgis-psc] Grants 2020 preparation for voting
Anita Graser anitagraser at gmx.at
Sun Jul 5 23:41:23 PDT 2020
Hi Nyall,
Yes, that sounds reasonable to me.
Regards,
Anita
6 Jul 2020 01:54:21 Nyall Dawson <nyall.dawson at gmail.com>:
> Hi Anita,
> If I recall correctly, when we've hit the situation in the past that
> there was a lower-voted project that fit within the remaining budget
> then we've previously "skipped" over the higher budget, higher voted
> proposal to also fund the lower budget proposals lower in the list
> until all the reserved funds are exhausted. Is this also going to
> happen this time? Basically it would affect whether or not part of the
> remaining 5.6k budget would be allocated to the 3k "QEP#177 MacOS
> Package Improvements" proposal.
> Nyall
> On Mon, 6 Jul 2020 at 00:57, Anita Graser <anitagraser at gmx.at> wrote:
>> The voting period is now over. I've closed the form and counted the votes. You find the preliminary results at:
>> https://docs.google.com/spreadsheets/d/10MAeENptW-gi8spkmR_jn0Y-_9iYakR7wtV5XdSZZ1o/edit?usp=sharing
>> As it stands now, the 8 top-ranked proposals can be funded within the 40k grant budget.
>> Could I ask you to please cross-check the results before we announce them.
>> Regards,
>> Anita
>> Gesendet: Samstag, 20. Juni 2020 um 16:18 Uhr
>> Von: "Anita Graser" <anitagraser at gmx.at>
>> The call for voting has been sent out now. The deadline is on Sunday, July 5th 2020.
>> Please get in touch if you are a voting member and haven't received the invitation.
>> Regards,
>> Anita
>> On 19.06.2020 18:01, Marco Bernasocchi wrote:
>> Thanks a lot Denis and  Anita for the great work!
>> Cheers
>> Marco
>> On 19.06.20 16:34, Andreas Neumann wrote:
>> Hi,
>> I agree - thanks a lot for your work, Denis!
>> It helps to get a good summary and present it a bit better.
>> Andreas
>> On 2020-06-19 16:24, Anita Graser wrote:
>> Thank you Denis!
>> I think this is an excellent overview of the proposals.
>> My goal is to send the call for voting out tomorrow evening if there are no arguments against it.
>> Regards,
>> Anita
>> On 19.06.2020 13:48, Denis Rouzaud wrote:
>> Hi Anita,
>> Here is a first draft of a one page summary of the grants to be voted on.
>> https://docs.google.com/document/d/1aiolvIpEGhBZ-iLhZl7cbUP1gPQx1-W83ecijpzNi4o/edit?usp=sharing
>> It's quite tricky to report the discussion without looking too negative. I hope this is neutral enough. I am totally open to suggestions, obviously.
>> Let me know what you think,
>> Denis
>> Le lun. 15 juin 2020 à 19:50, Anita Graser <anitagraser at gmx.at> a écrit :
>> Thank you Denis!
>> We need the summaries as soon as possible. According to our timeline, we wanted to publish the voting results at the end of June (after a two week voting period):
>> https://docs.google.com/document/d/1CNmSJxztrHrqLfillDH8v1zWaMzxFUyYSPT3sut55eQ/edit?usp=sharing
>> If you can manage to write the summaries by Sunday 21st, we can start the voting and have the results ready around July 6th.
>> Regards,
>> Anita
>> On Mon, 15 Jun 2020, 19:14 Denis Rouzaud, <denis.rouzaud at gmail.com> wrote:
>> Hi,
>> I can give a hand for this. I can compile the summaries and comments.
>> When is it due?
>> Denis
>> On Mon, 15 Jun 2020, 19:04 Anita Graser, <anitagraser at gmx.at> wrote:
>> Hi,
>> Do we have any volunteer for compiling the proposal and discussion
>> summaries?
>> If nobody is available to take care of this step - we have to decide if
>> we feel comfortable to go ahead with the voting without the summaries.
>> Regards,
>> Anita
>> On 13.06.2020 21:06, Anita Graser wrote:
>>> Hi,
>>> Since the QEP discussion period is over now, we need to take the next
>>> steps:
>>> According to our new process (discussed in
>>> https://github.com/qgis/PSC/issues/31), proposal and discussion
>>> summaries should be prepared that can be sent out to voters.
>>> @Paolo are you still available to take care of this?
>>> Regards,
>>> Anita
>>> Qgis-psc mailing list
>>> Qgis-psc at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
>> Marco Bernasocchi
>> QGIS.org Chair
>> http://berna.io
More information about the Qgis-psc mailing list
