[Qgis-psc] Grants 2020 preparation for voting
Matthias Kuhn matthias at opengis.ch
Mon Jul 6 08:38:23 PDT 2020
Hi Andreas
Thanks for taking this into the discussion.
Rest assured that no offense has been taken. I highly value the
democratic process and it's decisions!
It's an offer we decided to make to move a topic forward that in our
opinion would benefit the quality of QGIS and its ecosystem.
Looking forward to hearing from you
Matthias
On 7/6/20 5:29 PM, Andreas Neumann wrote:
> Hi Matthias,
> Tomorrow evening is a PSC meeting. I think we should discuss at the
> meeting what to do with the two proposals that couldn't make it.
> I wouldn't interpret the grant proposal voting as being "against" your
> proposal. With these relatively few voting members one vote plus or
> minus makes a difference and sometimes it is only a tiny bit of luck
> or not. This has nothing to do with the quality of the proposal.
> I think neither of the proposals is "sexy" to the end users. And the
> rules of the grant process made sure that "sexy" projects (new
> features and such) were not eligible for the grant process. We  should
> also not blame the voting members for the outcome - it is just a
> matter of fact that one or two of the proposals couldn't make it. I
> wish we had more funds than we had grant proposals ...
> It is also clear that certain proposals that only target a "minority"
> of QGIS  users (such as MacOS, Linux users or QGIS server users) often
> have a tough time getting enough votes.
> Greetings,
> Andreas
> On Mon, 6 Jul 2020 at 16:15, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
>     Hi Anita, all
>     Congratulations to all the winning proposals, we have some very
>     good projects confirmed. Also thanks a lot for running the grant
>     proposal process perfectly smooth.
>     Also thanks to all the voting members for taking the time to read
>     up on the proposals and participate in the democratic process.
>     We have noticed that the settings registry was again not
>     prioritized. We are unsure, what exactly the reason was. The other
>     proposals were very high quality indeed. Maybe it was not deemed
>     important enough, maybe the conclusion was that it would be easy
>     to find external sponsors or maybe it was not presented or titled
>     "sexy" enough.
>     Whatever it may have been, we are convinced that it would be very
>     good for the QGIS codebase, plugin ecosystem and users. It will
>      - reduce the risk for wrong usage of settings (recent bug e.g. [1])
>      - make it easier for plugin developers to properly use settings
>      - add semantics to settings, it opens up the way to generate a UI
>     for settings (the same way it's already possible to generate UIs
>     for processing parameters)
>     To provide this leap forward with respect to settings management,
>     OPENGIS.ch would like to jump in and sponsor the missing 2.4K € to
>     implement this proposal.
>     If you would like to follow up on this, please let me know.
>     Thank you very much
>     Matthias
>     [1]
>     https://github.com/qgis/QGIS/pull/37520/files#diff-45bc9c8c414931bca4589d3b221f119dL543
>     On 7/5/20 4:57 PM, Anita Graser wrote:
>>     The voting period is now over. I've closed the form and counted
>>     the votes. You find the preliminary results at:
>>     https://docs.google.com/spreadsheets/d/10MAeENptW-gi8spkmR_jn0Y-_9iYakR7wtV5XdSZZ1o/edit?usp=sharing
>>     As it stands now, the 8 top-ranked proposals can be funded within
>>     the 40k grant budget.
>>     Could I ask you to please cross-check the results before we
>>     announce them.
>>     Regards,
>>     Anita
>>     *Gesendet:* Samstag, 20. Juni 2020 um 16:18 Uhr
>>     *Von:* "Anita Graser" <anitagraser at gmx.at>
>>     <mailto:anitagraser at gmx.at>
>>     The call for voting has been sent out now. The deadline is on
>>     Sunday, July 5th 2020.
>>     Please get in touch if you are a voting member and haven't
>>     received the invitation.
>>     Regards,
>>     Anita
>>     On 19.06.2020 18:01, Marco Bernasocchi wrote:
>>         Thanks a lot Denis and  Anita for the great work!
>>         Cheers
>>         Marco
>>         On 19.06.20 16:34, Andreas Neumann wrote:
>>             Hi,
>>             I agree - thanks a lot for your work, Denis!
>>             It helps to get a good summary and present it a bit better.
>>             Andreas
>>             On 2020-06-19 16:24, Anita Graser wrote:
>>                 Thank you Denis!
>>                 I think this is an excellent overview of the proposals.
>>                 My goal is to send the call for voting out tomorrow
>>                 evening if there are no arguments against it.
>>                 Regards,
>>                 Anita
>>                 On 19.06.2020 13:48, Denis Rouzaud wrote:
>>                     Hi Anita,
>>                     Here is a first draft of a one page summary of
>>                     the grants to be voted on.
>>                     https://docs.google.com/document/d/1aiolvIpEGhBZ-iLhZl7cbUP1gPQx1-W83ecijpzNi4o/edit?usp=sharing
>>                     It's quite tricky to report the discussion
>>                     without looking too negative. I hope this is
>>                     neutral enough. I am totally open to suggestions,
>>                     obviously.
>>                     Let me know what you think,
>>                     Denis
>>                     Le lun. 15 juin 2020 à 19:50, Anita Graser
>>                     <anitagraser at gmx.at <mailto:anitagraser at gmx.at>>
>>                     a écrit :
>>                         Thank you Denis!
>>                         We need the summaries as soon as possible.
>>                         According to our timeline, we wanted to
>>                         publish the voting results at the end of June
>>                         (after a two week voting period):
>>                         https://docs.google.com/document/d/1CNmSJxztrHrqLfillDH8v1zWaMzxFUyYSPT3sut55eQ/edit?usp=sharing
>>                         If you can manage to write the summaries by
>>                         Sunday 21st, we can start the voting and have
>>                         the results ready around July 6th.
>>                         Regards,
>>                         Anita
>>                             On Mon, 15 Jun 2020, 19:14 Denis Rouzaud,
>>                             <denis.rouzaud at gmail.com
>>                             <mailto:denis.rouzaud at gmail.com>> wrote:
>>                                 Hi,
>>                                 I can give a hand for this. I can
>>                                 compile the summaries and comments.
>>                                 When is it due?
>>                                 Denis
>>                                 On Mon, 15 Jun 2020, 19:04 Anita
>>                                 Graser, <anitagraser at gmx.at
>>                                 <mailto:anitagraser at gmx.at>> wrote:
>>                                     Hi,
>>                                     Do we have any volunteer for
>>                                     compiling the proposal and discussion
>>                                     summaries?
>>                                     If nobody is available to take
>>                                     care of this step - we have to
>>                                     decide if
>>                                     we feel comfortable to go ahead
>>                                     with the voting without the
>>                                     summaries.
>>                                     Regards,
>>                                     Anita
>>                                     On 13.06.2020 21:06, Anita Graser
>>                                     wrote:
>>                                     > Hi,
>>                                     > Since the QEP discussion period
>>                                     is over now, we need to take the next
>>                                     > steps:
>>                                     > According to our new process
>>                                     (discussed in
>>                                     https://github.com/qgis/PSC/issues/31),
>>                                     > summaries should be prepared
>>                                     that can be sent out to voters.
>>                                     > @Paolo are you still available
>>                                     to take care of this?
>>                                     > Regards,
>>                                     > Anita
>>                                     _______________________________________________
>>                                     > Qgis-psc mailing list
>>                                     > Qgis-psc at lists.osgeo.org
>>                                     <mailto:Qgis-psc at lists.osgeo.org>
>>                                     https://lists.osgeo.org/mailman/listinfo/qgis-psc
>>             Qgis-psc at lists.osgeo.org  <mailto:Qgis-psc at lists.osgeo.org>
>>         Marco Bernasocchi
>>         QGIS.org Chair
>>         http://berna.io
> Andreas Neumann
> QGIS.ORG <http://QGIS.ORG> board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200706/b27278bb/attachment-0001.html>
More information about the Qgis-psc mailing list
